Clunk in front driver side and slows the truck down
Old Jul 30, 2007 | 05:12 AM
Tark's Avatar
Just about a week ago I have had an issue where I here a clunking noise in the front driver side area and the truck slows down.
It almost sounds like it is engaging 4wd and then not.
It happens mostly at lower speeds..say less than 20mph but has also happened at the 50mph range as well.
Any ideas what it might be?
4wd is off
Automatic tranny on my truck
Thanks
Old Jul 30, 2007 | 05:46 AM
toy_tek's Avatar
I'd definitely pull the wheel off and inspect the brakes as well as the CV shaft... sooner than later.
Old Jul 30, 2007 | 06:41 AM
BajaTaco's Avatar
4wd is off
Thanks
Are you sure it is the front? Have you had any blown rear axle seals in the past year or so by any chance?
Old Jul 30, 2007 | 07:01 AM
Tark's Avatar
i have not yet removed the front wheel...it very much sounds like it comes from the front.
I have not inspected the rear inner seals but have two new ones here when I have time to install.
Old Jul 30, 2007 | 08:24 AM
BajaTaco's Avatar
Ok, I just asked about the seals because I had a very similar problem, with the clunking and resistance to the truck rolling at low speeds. It ended up being brake shoes on the rear that had been fine for a very long time but were actually contaminated with oil from a leaky seal that had happened (and was repaired) long before the symptoms appeared.
gillesdetrail
Nov 19, 2019 12:56 PM
voiddweller
19
May 2, 2016 09:10 PM
WI Girl
Jun 25, 2015 03:45 AM
AustinTaco
Jun 21, 2015 09:54 AM
