Dash Lights Blinking W/ Turn Signals?
Old Jul 11, 2007 | 07:16 AM
Geographeen's Avatar
Just recently I discovered that my thermostat display and my speedometer flash, synchronized with my turn signals. The displays do not completely light up and turn off when the blinkers are engaged, but it is noticeable that they are blinking as well.
Anyone else had this issue?
Old Jul 11, 2007 | 07:21 AM
Toy-SkiTzo's Avatar
i had a similer problem with my 94, part of the wiring harnes go hot and the sheiling got soft causing the wirs to fuse together
Old Jul 11, 2007 | 10:56 AM
Elvota's Avatar
Do you happen to know how your battery is doing?
Sometimes a sign of it going out... sometimes....
My rig is way older, and I always get a little blinker fluctuation, so it might just be normal that you hadn't noticed before.
Now that you have though... it's going to drive you crazy.
Old Jul 11, 2007 | 11:05 AM
Toy-SkiTzo's Avatar
with mine every light except the headlights flashed with the directionals
Old Jul 11, 2007 | 11:28 AM
Elvota, the battery is pretty new so I don't suppose that is the cause of it. You could be right, I just may not have noticed it before.
Toy-SkiTzo, I am going to check into the wiring harnesses a little later. Like I had said before, I guess mine was not as involved as yours. Only my thermostat & steering column gauges flicker, not everything. Haha! I imagine there was quite a light show going on in your rig whenever you decided to turn!
Old Jul 11, 2007 | 11:33 AM
Elvota's Avatar
Just stop using your signals... you are in a 4Runner... most will get out of your way.
Old Jul 11, 2007 | 11:37 AM
lol! True, I usually don't but Atlanta sometimes proves to be a pretty defensive place to drive!
Old Jul 11, 2007 | 11:42 AM
Elvota's Avatar
Baaaaaahhh... rock sliders and MTR's work on more things than trails.
Old Jul 11, 2007 | 11:44 AM
and Bull Bars of course......for those stubborn ones!
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
