Engine vibrates in gear when stopped
Old Jul 3, 2007 | 11:22 AM
Shoretaco's Avatar
O.k. read through the other searches and found nothing really applied. My 2.7l auto Tacoma vibrates when you are stopped at a light or stop sign. It feels normal when in neutral or park. When you decellerate (spelling) you can feel it vibrate as you slow down. This just all of a sudden started there was no progression. Sometimes it is bad and sometimes barely noticeable.
Old Jul 3, 2007 | 12:59 PM
mjwalfredo's Avatar
I read that this might be a result of a worn out rubber exhaust support. I purchased a new one for my 4Runner but I have yet to try it out because the old girl needs a new thermostat housing before I crank her up again. I'll post my results when I am done.
Old Jul 3, 2007 | 02:08 PM
Caffeine's Avatar
how old are the plugs?
Old Jul 3, 2007 | 03:50 PM
Shoretaco's Avatar
Less than 5k. Why would it shake only in gear? and its worse in reverse. It shakes pretty bad when you put it in gear and keep your foot on the brake.
Old Jul 4, 2007 | 01:26 AM
Shoretaco's Avatar
Could it be the Torque converter since it only happens when trans is engaged?
Old Jul 4, 2007 | 05:59 AM
Sickrunner's Avatar
i have a 97 4runner borla k&N cold air after i put my borla on i noticed the same thing when i pull up to a red light when in gear it almost seems like it is the exhaust shaking when i throw it into N or P the shaking stops.
Old Jul 4, 2007 | 06:06 AM
Shoretaco's Avatar
Could be I just replaced my exhaust from the cat back so maybe that's it.
Old Jul 4, 2007 | 06:30 AM
toyotaoffroad91's Avatar
+1 thats what did it for me
Old Jul 4, 2007 | 08:38 AM
Skrillah's Avatar
I'd disagree, just rough idle. Try cleaning the MAF and the throttle body.
Old Jul 4, 2007 | 01:36 PM
Shoretaco's Avatar
O.k problem solved, my neighbor got under car and I put it in gear. When I got my new exhaust they strapped the muffler hangers to the heatshield bolts. On a tacoma they are directly under the passenger seat and are aluminum. Pretty soft metal and not strong enought to hold a muffler. Any way the entire exhaust was moving(vibrating) from the headers back. I took out the hangars and guess what no vibrations. I fabbed up my own hangar and bolted it to the frame and its all gravy from there.
Old Jul 4, 2007 | 03:36 PM
Ironmike4x4's Avatar
If I hadn't caught your thread earlier I would've suggested motor mounts. It's usually our number 1 culprit on GM stuff.
Old Jul 4, 2007 | 07:10 PM
Skrillah's Avatar
Key word there "GM"! Haha
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
mytruck
25
Jul 15, 2002 04:28 AM
