Drive Belts 5VZFE
Old Jul 5, 2007 | 06:59 PM
Knuckles's Avatar
Drive Belts 5VZFE
Iv search on here and 4x4 wire and still didnt find what i was looking for, is their a write up on how to change the 3 belts(A/C,Power Steering and Alternator) on the 5vz-fe?
Old Jul 6, 2007 | 03:13 AM
Elton's Avatar
i would like to know too i notice mine has a small split
Old Jul 6, 2007 | 04:54 AM
Knuckles's Avatar
I still didn't find anything. I was hoping for a tech write up with pictures.
Old Jul 6, 2007 | 05:47 AM
JHRRLD's Avatar
http://www.customtacos.com/tech/index.php?article=45
Check out the instructions for the TRD supercharger install. They walk you through removing the belts. That's when I changed all of mine.
Old Jul 6, 2007 | 06:27 AM
mkgarrison5's Avatar
man anyone have a condensed version?? with pics?
Old Jul 6, 2007 | 06:54 AM
Godzilla's Avatar
Then just use the ones that matter..Once the belts are loose they can be taken out by working them around the fan blades.
4. Loosen the pinch nut in the center of the A/C compressor belt
pulley and loosen the adjuster bolt enough to loosen the belt
(see arrow, figure 4).
5. Using the angled flat ratchet, loosen the pinch nut and adjuster
bolt for the power steering pump.
6. Remove the two belts.
7. Loosen the alternator pivot bolt (top), pinch nut and adjusting bolt
and remove the alternator belt.
Install is the reverse.. Pay attention to the order of the belts upon removal. This is wayy easier than you may think. If you can change your plugs, you can do this in like 30min.
Old Jul 6, 2007 | 10:25 AM
Knuckles's Avatar
Thanks Everyone, any info will help me. I want to gather all the info i can before i start taking things apart, i don't want to screw it up and have to take it to work ! I'am for sure going to buy toyota belts, everytime i buy after market they always end up giving me the wrong part or it just doesnt fit/work right.
Old Jul 6, 2007 | 10:36 AM
Godzilla's Avatar
It is pretty much obvious as you do it. I was nervous when i did it the first time since its the belts! ooooo.. Some of the bolts are a pain, and i did remove my airbox to make it easier for the PS belt. If you have a lift it makes life easier. Also remove the skid plates. And as mentioned the belts will snake over the fan blades with some turning.
edit, forgot to add. clean up the belt grooves of the pulleys and such while youre in there as grease and crud builds in there over time
Old Jul 6, 2007 | 10:43 AM
mjwalfredo's Avatar
How about belt tension. Do you really need the tool to check or can you judge by feel? If the tool is a good idea, is autozone/advance/carquest a good place to pick one up?
Old Jul 6, 2007 | 01:14 PM
Knuckles's Avatar
Here is what i don't understand, Which bolt is the pinch nut?
the Red one or the blue one? the blue one i thought is the 'lock nut'(thats what i thought it was called but i think now thats the pinch nut) for the adjuster bolt,I just want to make sure i don't unbolt the wrong one. I'm pretty sure its the lock nut you need to loosen and then unscrew the adjuster bolt? So once i loosen up the lock nut(pinch nut?) and then unscrew the adjuster bolt back it should be loose enough to come off correct? Thats how did the A/C Belt, Is it the same with the Power Steering belt or am i missing something?
The A/C belt was easy and everything is pretty much straight forward and more accessible than the power steering belt.
I'm not messing with the belts until i get some ratcheting wrenches, there is no way i can get a normal ratchet on the p/s adjuster bolt and it takes forever with a normal wrench.
Old Jul 6, 2007 | 04:51 PM
pattycakes77's Avatar
i just did my belts and did them by feel like all my other cars in the past. however, i wanted to make sure they were tightened enough and went to part store after part store and they all looked at me confused and said they didn't have anything like that. i also work at an auto dealership (not toyota ) and a guy selling Snap On tools came in and i asked him if he had one, but after searching he said there wasn't one on his truck or even listed in the catalog! according to my wonderful Chilton's manual (not!) the gauge is easily found at any auto parts store, not really.
good luck finding one, if you do let us know where you got it and for how much, thanks!
patrick
Old Jul 6, 2007 | 05:13 PM
GhostriderTx's Avatar
I found several hits on Amazon. here is one
http://www.amazon.com/Gates-Krikit-V.../dp/B000AOEJOE
Old Jul 8, 2007 | 12:43 AM
Adam F's Avatar
Here is my write up for a 3vz, should be basically the same
http://home.4x4wire.com/adamf/88/belts.htm
Old Jul 8, 2007 | 10:32 AM
Knuckles's Avatar
Yeah, its the same as the 5vz, thanks adam!
Old Jul 8, 2007 | 12:59 PM
thanks ghostrider! i never think to look on amazon, and for $20 i'm ordering one right now.
thanks again,
patrick
Old Jul 26, 2007 | 08:34 AM
07sbock's Avatar
Be warned! replacing these belts are not as easy as one would think. Not the same at all as the 3VZ!
Old Jul 26, 2007 | 09:57 AM
mjwalfredo's Avatar
I did it for the first time myself a few days ago. It really is not hard at all. The only tricky part was tightening the nut for the power steering belt because of where it is located. Other than that, it was a breeze. I didn't use a tool to check the tension either and all seems good...
jasonty
41
Dec 23, 2018 01:00 PM
dinks07
Jul 15, 2015 05:34 PM
jon.r
Jul 11, 2015 03:34 PM
nick b
Jul 11, 2015 04:38 AM
Cplmike
Jul 8, 2015 08:47 PM
