1 1/2"front tow bar hook ups?
Old Jul 5, 2007 | 07:32 AM
Guest
Guest
Posts: n/a
Before I bought my runner It was lucky enought to find most of its time behind a motorhome (its a 97 with 93,000mi has a tow bar hook up welded to the front of the frame and a trailer adapter wired into the engine compartment).
The tow bar mounts are welded on and look to be about 1 1/2". Does anyone know of a trailer type hook I can add to these like the ones you can mount in the rear? And be able to place shackles on and also a bumper that will clear them keeping them usefull? Their welded on the outsides and under the frame, so I planed on beafing up the small tack welds a little and dont feel like grinding and cutting.... Or is it a lost cause and just cut them off and put on a bumper with tow points?
Thanks
Old Jul 5, 2007 | 08:58 AM
shiftless89's Avatar
pictures are required before answer is provided, good detailed photos of were its welded, both sides and bottom please
Old Jul 5, 2007 | 10:11 AM
Guest
Guest
Posts: n/a
Ill have them up here shortly
Old Jul 5, 2007 | 10:35 AM
Guest
Guest
Posts: n/a
here are the pics the close up is the right side if looking at the front or left side if sitting in it. ITs got 2 bolts holding it on as well as welds around. Once again thank you all for your help.
Old Jul 8, 2007 | 08:01 AM
Guest
Guest
Posts: n/a
Still looking for help on this
Old Jul 8, 2007 | 08:16 AM
wormhole's Avatar
Is this what your wanting:
http://www.wheelersoffroad.com/4runnertowstrap.htm
(scroll down a bit)
Looks like you need to clean up and paint those areas as well.
Old Jul 8, 2007 | 09:59 AM
Guest
Guest
Posts: n/a
thats what Im looking for but im guessing thats the normal reciver size? these are about 1/2" smaller than the rear. should I just leave them and get a tow bar? And put it up in front of the bumper like some rigs I see?
88sasturbotoy
Jan 30, 2026 01:57 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
crashburnoveride
Jul 10, 2015 06:39 AM
