slow to start
Old Jul 23, 2007 | 07:18 AM
Sandman's Avatar
slow to start
My 3.4 seems to need to turn over for a few seconds before it fires up. It always starts, and the starter motor seems to be doing it's job. Is this normal for it to have to crank several times before starting? (My 22re fires up almost instantly).
The 3.4 has new sparkplugs, fresh oil, and I cleaned the intake area.
Old Jul 23, 2007 | 07:26 AM
Ringmaster's Avatar
Mine does the same as yours, especially when it's been sitting over overnight, or for 6-8 hrs.
Old Jul 23, 2007 | 07:59 AM
irunner's Avatar
Mine is doing the same thing, usually starts up on the 2nd crank but this morning it took about 5 minutes to start up.
Old Jul 23, 2007 | 08:10 AM
engineerjoe's Avatar
sounds like a problem with the fuel or ignition system. next time try to let it sit for 30 secs with the key in the "on" position (to let the fuel system pressurize) before you turn it over. Let us know how it goes.
Old Jul 23, 2007 | 09:18 AM
Joshs98Runner's Avatar
also get a volt meter on the battery and tell us what it reads sitting cold.
Old Jul 23, 2007 | 09:53 AM
kevin444's Avatar
check out my "clean your IAC" thread.
Old Jul 23, 2007 | 07:51 PM
R1-4Runner's Avatar
When I jumped to a 800 cold cranking amp battery (550 stock) it started like a jet engine compared to before... this is, if its your battery.
Old Aug 13, 2007 | 05:59 PM
Sandman's Avatar
-I cleaned the gunk out of the throttle body and iac
-tried turning the key and waiting before starting
-battery is sitting at 12.80Volts after sitting for 45mins.
-battery is 750 cca at 32F.
Still doesn't fire up as fast as my 22re.
any ideas?
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
