starter clicking but not starting
Old Jul 17, 2007 | 06:23 PM
gonzopb's Avatar
I helped a buddy of mine change his starter on a 1998 4 runner 3.4 auto a few weeks ago. the stater has been working fine until tonight. when he tried to start it i can hear the fuel pump starting but then there is just a loud click. the battery voltage is fine as well. has anyone had this problem or advice on what to look for?
thanks
brian
Old Jul 17, 2007 | 06:26 PM
locked stock 84's Avatar
Check batt. cables and starter cables. If the voltage is good, it sounds like loose cable.
Old Jul 17, 2007 | 06:58 PM
CJM's Avatar
CJM
Loose cabling or its toast.
Me, I would get a nice pipe and give it a bang and see if it gets going if your stuck somewhere with it.
Old Jul 17, 2007 | 10:33 PM
86tuning's Avatar
Used or reman starter? Or did you change the contacts?
Changing starter contacts is pretty easy...
And a single click from the starter = failed contacts. Or possibly bad main power wire.
Old Jul 20, 2007 | 06:25 AM
gonzopb's Avatar
i believe the starter was a reman. it was from autozone.
Old Jul 20, 2007 | 06:32 AM
Sandman's Avatar
try tapping the started hard with something metal (like a pipe) while someone turns the key..if that works, probably the contacts -you can get them cheap from Roger Brown
Old Jul 20, 2007 | 07:45 AM
hross14's Avatar
Those IMO are not so good. Got the parts from roger Brown and Rebuilt mine--cost me 20$ and an hours worth of work. just clean, Replace and grease. Easy job
Old Jul 21, 2007 | 03:57 AM
Beartracker's Avatar
Mine did the same thing two years ago. My mechanic pulled it, cleaned it real well and rebuilt it and it has worked perfectly. I bought the rebuild kit but don't remember what I paid for it but it was cheap. He charged me $20.00 to for the whole deal...pull it , clean it, rebuild and re-install. Took him less than an hour. Mike
Old Jul 21, 2007 | 04:50 AM
4Crawler's Avatar
See page below for a simple test to help find the cause of the problem:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
razorman8669
Jul 12, 2015 12:13 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
