Are there any .5" rear spacer lifts? The smallest I have found is 1" (yes I searched)
Old Jul 27, 2007 | 09:20 AM
UNR.Grad's Avatar
My front end and back end are exactly equal right now, but I like the aggresive raked look. If I could raise up the rear just 0.5" it would look perfect, but 1" would be too much, any help would be appreciated. Thanks
Old Jul 27, 2007 | 09:30 AM
mehret's Avatar
uhh...
Old Jul 27, 2007 | 09:31 AM
MillerPKA's Avatar
forget what mehret said. i don't think they make .5s. you could ask cornfed to make a custom pair. either that or buy 1" and grind them down
Old Jul 27, 2007 | 09:58 AM
Godzilla's Avatar
what type of rear springs? try some OME 10mm trim packers. They are a polyurethane as well and fit between the bumpstop spring seat and the spring.
edit..i cant see the type of rear springs making a difference considering where they go.
Old Jul 27, 2007 | 10:42 AM
Whitey13's Avatar
I'd have a hard time believing 1/2 inch would be noticeable... although I could be wrong. Do you have a pic of how it sits currently?
Old Jul 27, 2007 | 10:44 AM
MillerPKA's Avatar
for the small amount of rake he's looking for 1/2" will be perfect, if he gets it done you can definitely tell with the proper b/a picture
Old Jul 27, 2007 | 06:24 PM
UNR.Grad's Avatar
Originally Posted by mehret
uhh...
Thank you for contributing.
Old Jul 27, 2007 | 06:25 PM
UNR.Grad's Avatar
Thanks, never considered that but it might work perfectly.
Old Jul 27, 2007 | 06:34 PM
UNR.Grad's Avatar
I think .5 would be noticeable, my old setup was .5 off and I could notice, atleast I told myself I could, haha .
Here it is now (pics were take in March)...
Old Jul 27, 2007 | 06:35 PM
UNR.Grad's Avatar
The tops of the coils should be the same right, they both sit into the same upper bumpstop? Any idea where I can get those?
Old Jul 27, 2007 | 09:27 PM
BajaRunner's Avatar
Get the 1" daystars. You'll hardly notice the difference of .5"...
Old Jul 28, 2007 | 06:35 AM
Maj's Avatar
Maj
When I participated in the rear spring recall all the Stealer did was insert the cone bumpstops (no new springs :-(). I definitely noticed the 5/16s of lift from the cones. When I put my spacer lift in, I had too much rake going on so I removed the cones for an again noticeable difference.
Old Jul 28, 2007 | 08:10 AM
frodin1's Avatar
Daystars are pretty spendy as are Cornfed? Mine sits about the same. I'd be interested in this as well. I have the Tundra/890 lift and mine sits the same as UNRGrad's. I really didn't want to go with a more aggressive spring to maintain the ride quality. What to do? I've been thinking of buying that Plastic crap that they were making the front "bam" spacers with, and routing a cove groove into it for the springs to rest in. I believe you can get that stuff any thickness you'd want right? HMMmmm.
Old Jul 28, 2007 | 08:37 AM
UNR.Grad's Avatar
Do you have the cones still, maybe those would work for me?
Old Jul 28, 2007 | 08:46 AM
MillerPKA's Avatar
go to the dealership they'll do it, just call and make an appointment for the rear coil recall
Old Jul 28, 2007 | 08:51 AM
frodin1's Avatar
That wont work if your vehicles not involved. They'll run your Vin and see if your vehicles included in the recall. I was able to check online somewhere and it said mine was not involved.
Old Jul 28, 2007 | 09:21 AM
Maj's Avatar
Maj
I plan on hanging on to them for possible future mods or if the rear ever begins to sag. You might be able to scratch some up by posting a "Wanted" ad in the for sale section.
Old Jul 28, 2007 | 09:39 AM
frodin1's Avatar
Hey UNR, Pm "Bighead" He told me the other day that he has a set of Cornfed 1" spacers for sale. These things sell for $100. He told me $60 plus shipping. I'm gonna pass. I didn't want to spend that much. I can't justify spending more money on these stupid spacers. I should have just kept my Daystars and cut them down.
Old Aug 3, 2007 | 07:40 AM
BennyTRD's Avatar
After I did the 99 coil swap, I noticed that the truck sat too even with the new coils after they settled. I could have added air to the rear bags, but I found that it seem to kick more that i'd like without any weight. So I ordered a set of OME Trim Packers to add 10mm or .393in of lift to the rear to have a bit of rake.
Old Aug 3, 2007 | 04:00 PM
BennyTRD's Avatar
Here's a before and after picture with the OME Trim Packers.
