PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. New to Forum & New to me 99 4Runner (pics)
  2. tailgate wont open
  3. Help with front bumper install on 98 tacoma SR5
  4. Parking brake adjustment problem - only engages one side
  5. 99 4Runner EGR Valve Temp Sensor
  6. Testing Ignition Coils in my '97 3vz-fe 4x4...
  7. first timing belt/water pump replacment
  8. how common was the rear locker?
  9. 3rd Gen Possible Ram Air?
  10. stripped intake manifold
  11. Problem installing axle seals
  12. 98 3RZFE 2.7 - stumbling, acceleration, misfire issues?
  13. 3rz injectors not getting pulse
  14. post your 3rd gen 4runners and your mods
  15. rear hatch power lock does not work
  16. Temp Guage issue
  17. Inner half shaft boots leaking, both sides
  18. 880 and 906 COILS on a 1998 4Runner 4WD
  19. New Rig Has Rust
  20. 01 4runner torque converter lockup
  21. 01 4runner alarm has locked ignition
  22. Front running lamps work - dash and taillights don't
  23. suspension help!!!
  24. Hard downshift, when coasting
  25. Supercharger nosecone holes
  26. What is the purpose of this?
  27. What type of shocks are these? 2003 Taco
  28. 01 4runner 4wd not working
  29. fuel pressure differences
  30. Trouble putting in gear
  31. Replacing motor ?
  32. Safari snorkel + Deck plate mod?
  33. Tundra 199mm Front Disc Upgrade Success
  34. New pinion bearings and locker clean out. Help needed
  35. 01 4runner horn pad replacement
  36. Slow start up 3.4
  37. 02 4runner AWD not engaging dash lights blinking
  38. crank pully holder in San Diego?
  39. Sonoran Steel 12st gen roll bar for 3rd gen
  40. Transmission type
  41. 3rd gen 4runner upgrades
  42. Read End Noise
  43. Temp sender comparison Autometer vs Glowshift
  44. Can you make the rear window roll up from outside the 4R?
  45. Heim/Rod End size
  46. Got boost?
  47. Fabtech 6 inch lift rear block size?
  48. CEL After mods
  49. Reman cv axles recommendations
  50. Misc questions about my new-to-me '00 PreRunner
  51. Front wheel bearing install question
  52. 1998 4Runner Clutch and Power Steering Pump Replacement
  53. How To: Wiper Resivoir Relocation
  54. TRD supercharger install
  55. Adjusting front wipers / motor?
  56. Questions regarding towing and 32" tires
  57. changing a head gasket
  58. Are Tacoma & 4Runner Seats & Cab Different?
  59. GM 4.3 swap
  60. Engine Stalls when warm
  61. making lemon aid from lemons
  62. 2002 385's 4.10 gears. Am I missing something?
  63. T4r4life CB Antenna Mount
  64. Fixing old 1st gen suspension. New leafs (plus lift)
  65. 01 4Runner low brake pedal???
  66. Oh nooo what did they dooo!!!!??? paint repair gone bad
  67. Tacoma 3.4L Low rpm lag
  68. Help with rear suspension
  69. Gas fumes inside 2000 4runner
  70. Door Armrest Screw Part Number?
  71. Strawberry Milkshake? Swollen Rubber Gaskets? Transmission Radiator Line
  72. Chop top 3rd Gen 4Runner, advice please
  73. 2000 4Runner: Highlander?
  74. What's Up With My Baattery Terminal?
  75. Another 97 4Runner Head Gasket bites the dust...now what?
  76. fabtech coils or keep my tough country spacers
  77. Weird problem with 01 4Runner......
  78. Diagnose fluid leak under throttle
  79. 96 Tacoma overheating again
  80. new tires :)
  81. 2.7 Head Problem
  82. 2002 Toyota 4Runner 4X4 making loud bang when shifting into Drive or Reverse
  83. Not moving when letting off the brake?
  84. ARB Taco Bars for 3rd gen 4Runner
  85. 1st Gen S/C Gaskets??
  86. New Lift, New Tires. What Size?
  87. Climate control 02 ltd.
  88. Tire sizes on 97 4runner.
  89. Toyota cv axles
  90. Limited Climate Control Question
  91. To flush once more, or not to flush. That is the question (A340F)
  92. 3rd gen 4runner tow hook install & temp guage
  93. 3rd gen 4runner aux light switch install (pic)
  94. 3rd Gen Roof light install (pics)
  95. OK I screwed up my 4runner o2 sensor wire connector ??
  96. Buying a 2001 4runner... worth it??
  97. 98 Tacoma 2.7L Misfire and test results
  98. How to check fuel pressure?
  99. Aftermath of TB cleaning
  100. Skid row off road
  101. vsc off button???
  102. 96' 2WD Runner w/oil leak
  103. Icon UCAs with regular coils/shocks
  104. Opinions needed
  105. Expected performance going from spacer suspension to Toytech Coil overs???
  106. Brake vibration
  107. V6 or 4cyl
  108. ?? Anyone have problems installing Airaid modular intake tube??
  109. Gas gauge problem
  110. Operation: Olive Drab PATYWGN
  111. Front Transfer Case Seal
  112. Swapping front diffs
  113. 04 Tacoma bearings?
  114. External Temperature Gauge
  115. Replacing Limited Rear V6 99 Inner Oil Seals Rear Axles
  116. 02 Tacoma Rear Bumper Build and Rear Quarter Chop
  117. "New" 2004 Tacoma (with iphone pics!)
  118. Noob Relay question
  119. Thank you
  120. 97 4Runner SR5 suspension help needed
  121. Leaf Spring Recall - 04 D-cab
  122. Time For A New Stering Rack
  123. Power Steering Groan in Steering Wheel???
  124. Racks that go around the camper shell
  125. 97 4Runner Stalled on Interstate. Mechanic Says Idle Control Valve?
  126. Bogging
  127. How to repair frame rust or atleast extend frame life?
  128. Coilover ID?
  129. Engine Starting Problems
  130. AC Clutch or Compessor?
  131. 99 Tacoma Rear Locker Won't Disengage
  132. Piecing together a Toyota 2wd brake upgrade!! (Must read)
  133. Tundra brake upgrade and 16 stock steel wheel size
  134. Dorman harmonic balancer quality?
  135. Taco Zuk Mod Question?
  136. Braking issue - possible LSPV
  137. ? is Bil 4600s w/ F 881s and R 906s a good match?
  138. Cold Air Intake
  139. AC electronics issues?
  140. Tacoma Seat Swap
  141. Help identifying a missing part
  142. Gas mileage slowly decreasing, slight hesitation constant
  143. 99-04 maf sensor
  144. Where would you start with this 99 runner stalling problem?
  145. Tacoma HELP !!!!
  146. 2004 Tacoma Crew Cab Automatic to Manual Conversion
  147. 99 runner front mud flaps?
  148. 3rd gen remote help
  149. New Computer Needed due to lost master key??: 99 4Runner
  150. Swapping sagging struts with what new model?
  151. RS3000 Alarm Has No Power
  152. Shift Solenoid going bad?
  153. 97 4Runner Flex Plate
  154. Fan motor
  155. front and rear diff seal replacement
  156. Rear Storage Compartment
  157. o2 censor check engine light
  158. LCE Intake and K&N CAI Question
  159. engine knocking after rollover
  160. S/C Bearing Press Near Sacramento Area?
  161. Need Urgent Help.... Stuck on the rd !
  162. transmission issue
  163. 1995.5 Tacoma RPM ?'s
  164. Introduction/New to me 4Runner
  165. 4runner frame swap
  166. 1998 4runner Auto Tranny Flush Redline D4 ?
  167. Highway RPMs
  168. 02 headlight upgrade
  169. CEL code p0170 fuel trim malfunction need help!!
  170. Newb has questions about 3rd gen 4runner build
  171. My New 4runner!!!!!
  172. Issue post tundra brake upgrade
  173. Cheap Denso Dual Electrode Spark Plugs
  174. A/C only blows cool when moving???
  175. Taco Time
  176. Starter issues after water crossing. Replace starter or just contacts?
  177. Completed my T-belt; Thanks!
  178. Switching Tacoma electic huds to manual
  179. Denso coils for V6 3rd Gen 4Runners?
  180. erratic oil pressure
  181. Broken tie rod symptom
  182. Accessory Pulley Debacle
  183. 2002 4Runner Keyless Entry Question
  184. My sloppy runner - need advise
  185. 4runner parts??
  186. 2000 Tacoma Front E-brake cable replacement!!
  187. CEL came on code P0171
  188. 01 Tacoma lift thoughts
  189. 4Runner issues to look out for????
  190. Um winter is around the corner. Front end help?
  191. Heater/Air Conditioning fan motor ?
  192. Jerking on Acceleration...
  193. LED kits for 1998 4WD 4runner
  194. I want my Toyota Tacoma to chirp off the line and burn rubber...
  195. Do 2000 4runners have transponder keys ?
  196. Timing belt destruction
  197. 2002 Tacoma 3.4 Rough Idle / Chugging Problem!
  198. New clutch, vibration at idle?
  199. Just got a 4runner, need some more information
  200. CEL - Code P1600 (ECM?)
  201. Crack in fuel float?
  202. Power steering return hose leak... question
  203. 3RZ with W59 throwout bearing help.
  204. trans issues
  205. Tacoma 3.4L Engine Knock (NOT the typical 3.4 ticking)
  206. Please look at my crankshaft pulley..
  207. 95 4runner SR5 continually overheating
  208. New radiator...Still need external tranny cooler??
  209. Ignition lock cylinder problems!!!
  210. Sway bar bracket and bushing
  211. Advice for Tuning a 220k 98 2wd auto 3.4
  212. Changed the ignition Column, but the key still turns loosely and does not start.
  213. Slight engine knock, need opinions
  214. Could not part with my 2000 4Runner
  215. fixed high idle now ac clutch wont engage
  216. Oil pressure sending unit
  217. hydrolock?
  218. Which automatic transmission can I use in my '99 4Runner Ltd?
  219. a quick elocker question
  220. 4Runner Body lift/shifting question
  221. Tacoma Clutch Question
  222. Tacoma transfer case compatibility with other models
  223. Engine Stumble at High RPM
  224. Front End grinding
  225. Quick question
  226. New clutch-will bump start but won't crank
  227. 1999 Taco Door Lock Stuck
  228. 1999 4Runner Oil Change Advice
  229. New frame - different dimensions?
  230. Best shocks for '99 LTD 4WD?
  231. Is there a 12V Yota electrical genius in the house?
  232. Power steering problem
  233. rear bumper help needed
  234. Inorganic ZINC silicate primer for rust prevention...the real deal?
  235. 4runner crushed by tree and still drives
  236. Opinion: 94 Toy PU 3.0; 99 Tacoma
  237. engine sputters after warm up
  238. Glovebox Organizer
  239. 96 4Runner Fuel Pump Issue (Stumped Two Mechanics)
  240. 1998 4runner CEL PO753 ????
  241. kickdown cable
  242. '97 4Runner High Idle - with IACV 1800rpm/without 1000rpm
  243. Question about speakers and amp on 00 4runner
  244. need FSM for 98 tacoma
  245. Pic request interior shots
  246. Air in the cooling system!!!
  247. Grinding/whooshing sound from front right
  248. 98 Taco high idle/rough cold start
  249. SR5 Limited Rotors Question
  250. Driver's Side Door Lock Popper
