stripped intake manifold
Old Aug 30, 2012 | 07:25 AM
mschein1's Avatar
Was cleaning the IAC and stripped the bottom holes of the intake manifold. So went and bought a tap and die, I tapped to big of a hole. Am I now screwed? Where can I get an insert for m10 so that I can still use the m8 bolts?
Old Aug 30, 2012 | 07:28 AM
waskillywabbit's Avatar
Local industrial/fastener shop or auto parts store. Try your yellow pages.
:wabbit2:
Old Aug 30, 2012 | 07:31 AM
mschein1's Avatar
I already tried the auto parts store, all they had was helicoils. Do they make a m10 insert that you can thread the m8 bolt into?
Old Aug 30, 2012 | 09:15 AM
j2the-e's Avatar
Try timesert.com
Old Aug 30, 2012 | 09:48 AM
mschein1's Avatar
I called my local Fastenal and I think they have them, running over there after work today.
Crossing my fingers
Old Aug 31, 2012 | 07:50 AM
mschein1's Avatar
Ok no luck with a helicoil, ended up ordering a new upper intake manifold. Question, do I just need one new gasket for this? The old one I assume is not reusable correct?
Old Aug 31, 2012 | 09:00 PM
j2the-e's Avatar
Did you even check timeserts out? They have exactly what you would have needed to fix it. Why ask for advice and then ignore it?
http://www.timesert.com/html/bigsert.html
It's a steel gasket. Reuse it if it looks ok. Install it dry.
Old Sep 1, 2012 | 12:50 AM
wyoming9's Avatar
Red face
:wabbit2: wow I thank you for this link!!!!
I had never come across them before. Some of these will be a great edition to my interesting goodies for fixing failures of thread repair jobs.
To bad the OP never checked them out it seems .
Old Sep 6, 2012 | 06:34 AM
mschein1's Avatar
I tried this exact same thing from my LOCAL fastenal..I messed up the threads bad. Got a used upper intake manifold for 30 bucks. I did not ignore anything.
Old Sep 6, 2012 | 10:39 AM
j2the-e's Avatar
Cool. Good deal!
Old Sep 6, 2012 | 11:23 AM
Yotard's Avatar
wyoming you may like these even better, Keenserts. I use these all of the time as a machinist, for thread repair or high use/strength threaded application, and highly recommend them.
http://www.mcmaster.com/#key-locking...nserts/=j6e162
Corvoid
Dec 11, 2015 11:21 AM
Marley2984
Dec 6, 2015 05:19 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
jacked_72
Sep 14, 2015 03:31 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
