Temp sender comparison Autometer vs Glowshift
Old Aug 20, 2012 | 07:28 AM
DRCOFFEE's Avatar
I am installing a transmission temp gauge in my rig to the left of the steering wheel in the dead switch area. So I bought and installed a Glowshift gauge and I really do like it but it has a magnefied lense which makes it hard to read where I have it installed. So I bought a new Autometer gauge 2640 to replace it.
Now both gauges come with a sender and I searched across the web for a Ohm map to compare the two senders. Why change out the glowshift sender if its compatible with autometer gauges? Well it looks like it a direct replacement. The reason for this thread is to let you know the glowshift sender is a 2 wire sender which will make grounding it a little easier and a cleaner install.
Here are the Resistance (Ohm) maps for each brand.
Here's what I found when I emailed Glowshift's tech dept.:
Glowshift
Ohms.....Degrees F*
925.........104*
438.........140*
224.........176*
120.........224*
68...........248*
41...........284*
Autometer
Auto Meter 2258/2259 Thermistor Specifications
Temperature = Ohms:
100°F = 1123Ω ±102Ω (Enter 999 - above this, ECU defaults to 'Ohms x 10'.)
120°F = 708Ω ±59Ω
140°F = 460Ω ±35Ω
150°F = 374Ω ±27Ω
170°F = 253Ω ±17Ω
190°F = 175Ω ±10Ω
200°F = 149Ω ±8Ω (I mathematically averaged this in, for 16 data points.)
210°F = 123Ω ±7Ω
212°F = 119Ω ±6Ω
220°F = 105Ω ±5Ω
230°F = 89Ω ±5Ω
250°F = 65Ω ±4Ω
280°F = 42Ω ±3Ω
300°F = 32Ω ±2Ω
320°F = 25Ω ±2Ω
340°F = 20Ω ±1Ω
And just in case you may be curious about the other Autometer sender:
Auto Meter 2252 (Delphi 12160855) Thermistor Specifications
Metri-Pack mating connector ~ 12047662 & TPA lock ~ 12047664
Metri-Pack terminals ~ 12047767 .039"-.031" & 12064971 .020"-.014"
Temperature = Ohms:
-40°F = 402392Ω ±1.8°C
-31°F = 288981Ω ±1.8°C
-22°F = 209817Ω ±1.8°C
-13°F = 153922Ω ±1.8°C
-4°F = 114026Ω ±1.8°C
5°F = 85256Ω ±1.8°C
14°F = 64306Ω ±1.8°C
23°F = 48910Ω ±1.7°C
32°F = 37499Ω ±1.7°C
41°F = 28977Ω ±1.7°C
50°F = 22572Ω ±1.7°C
59°F = 17717Ω ±1.7°C
68°F = 14007Ω ±1.7°C
77°F = 11150Ω ±1.7°C
86°F = 8935Ω ±1.6°C
95°F = 7204Ω ±1.6°C
104°F = 5844Ω ±1.6°C
113°F = 4768Ω ±1.6°C
122°F = 3911Ω ±1.6°C
131°F = 3226Ω ±1.5°C
140°F = 2676Ω ±1.5°C
149°F = 2232Ω ±1.5°C
158°F = 1870Ω ±1.5°C
167°F = 1574Ω ±1.4°C
176°F = 1331Ω ±1.4°C
185°F = 1131Ω ±1.4°C
194°F = 964.7Ω ±1.3°C
203°F = 826.2Ω ±1.3°C
212°F = 710.2Ω ±1.3°C
221°F = 612.9Ω ±1.2°C
230°F = 530.9Ω ±1.2°C
239°F = 461.5Ω ±1.2°C
248°F = 402.6Ω ±1.1°C
257°F = 352.3Ω ±1.1°C
266°F = 309.3Ω ±1.1°C
275°F = 272.4Ω ±1.1°C
284°F = 240.6Ω ±1.1°C
293°F = 213.2Ω ±1.1°C
302°F = 189.3Ω ±1.1°C
Update: I swapped out the glowshift with a Autometer gauge after verifying the gauges were reading the same temp once I brought it up to operating temperature.
Just an aside. I was able to scrounge a nice 2 wire weather pack electrical connector off of a Volkswagon in a junk yard to replace the bullet connectors in the picture above. I paid $2 for 3 of them. This make maintenance in the future much easier.
Old Aug 21, 2012 | 05:56 AM
Texas_Ace's Avatar
I would get a pillar pod for the gauges personally, a lot cleaner and can be undone later if you decide you want to change things up. Also allows you to install a few gauges in direct line of sight.
Far as the sender, up to you, you can most likely use either sender but the readings may be screwed slightly.
coryc85
Dec 5, 2015 08:42 AM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
--Oz--
Sep 6, 2015 01:06 AM
