96 Tacoma overheating again
Old Aug 10, 2012 | 10:58 AM
keoni1101's Avatar
My 96 tocoma still overheating. I've replaced my head gasket, water pump, thermostat, radiator cap and timing belt. I've also bleed the air from my cooling system. I pressurized my cooling system and it held at 15-16 PSI. Found no leaks. I need help desperately. I don't know what else to do.
Old Aug 10, 2012 | 03:56 PM
Dirt Driver's Avatar
Under what conditions is it overheating? Standing still? Driving at low speed? Driving on the highway? Did you replace the head gasket to fix this problem or had the gasket failed? How old is the radiator/how many miles are on it?
Old Aug 10, 2012 | 04:33 PM
keoni1101's Avatar
It started to overheat when I went up a steep hill. I had my head gasket replace because it was blown. But the radiator is original. 146,467 miles.
Old Aug 11, 2012 | 04:13 AM
DRCOFFEE's Avatar
If the juggler on the t stat is not in the 6 o'clock position' it will overheat.
Matt89toyota
Jun 27, 2023 08:00 AM
4x4YOTA
Aug 23, 2016 09:08 AM
G-off
Dec 29, 2015 12:44 PM
Project90
Sep 24, 2015 11:40 PM
LotOMiles
Sep 14, 2015 11:45 PM
