96 Tacoma overheating again
Old 08-10-2012, 10:58 AM
keoni1101's Avatar
My 96 tocoma still overheating. I've replaced my head gasket, water pump, thermostat, radiator cap and timing belt. I've also bleed the air from my cooling system. I pressurized my cooling system and it held at 15-16 PSI. Found no leaks. I need help desperately. I don't know what else to do.
Old 08-10-2012, 03:56 PM
Dirt Driver's Avatar
Under what conditions is it overheating? Standing still? Driving at low speed? Driving on the highway? Did you replace the head gasket to fix this problem or had the gasket failed? How old is the radiator/how many miles are on it?
Old 08-10-2012, 04:33 PM
keoni1101's Avatar
It started to overheat when I went up a steep hill. I had my head gasket replace because it was blown. But the radiator is original. 146,467 miles.
Old 08-11-2012, 04:13 AM
DRCOFFEE's Avatar
If the juggler on the t stat is not in the 6 o'clock position' it will overheat.
Matt89toyota
06-27-2023 08:00 AM
4x4YOTA
08-23-2016 09:08 AM
G-off
12-29-2015 12:44 PM
Project90
09-24-2015 11:40 PM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: 96 Tacoma overheating again
