Crack in fuel float?
Old Jul 8, 2012 | 08:48 PM
Doug18's Avatar
Ok, so I was freaking out a little bit earlier today on my way to the beach because my fuel gauge was dropping at a rate of about 7.5-8 mpg. I had replaced my drive belts earlier today so I initially thought that I may have forgot to re-connect something but after a lenghty search that turned out to not be the case, everything was as it should be. So I continued to drive and figured I would just bite the bullet and pay the premium this time and dig into it tomorrow after class. However, on the return trip I stopped to refuel because the gauge was reading just below 1/4 of a tank, but surprisingly it was full to the cap at just about 7 gallons and I had actually gotten 18 mpg which is about on par for over 20 miles of beach driving. So now I am baffled as to what could be wrong with my truck. Any ideas?
Old Jul 8, 2012 | 11:18 PM
wyoming9's Avatar
Talking
Just what formula were you using to calculate this fuel consumption by the movement of your gas gauge??
I would have to make a guess your sending unit is on the way out
Old Jul 9, 2012 | 10:17 AM
enapa's Avatar
Isnt a known common issue that the gauge tends to fail on the third gens? I know mine doesnt work.
Old Jul 9, 2012 | 11:24 AM
Doug18's Avatar
Just from previous experience with calculating mpgs (I calculate my mpg every time i fill up using odometer reading/.92(correction for tires) / Gallons I feel it is fairly accurate because I always fill the tank up to the same level
so I was able to look at how many miles I had gone look at the tank reading and roughly estimate that my fuel mileage was 3/8 of what it usually is
Old Jul 9, 2012 | 11:25 AM
Doug18's Avatar
Hmmm did not know that ... mine has been pretty darn accurate before this episode
Old Jul 10, 2012 | 12:44 PM
enapa's Avatar
I read it somewhere but cant remember where. From what i read the only way to remedy the situation is a whole new cluster. I resigned myself to just using the trip meter. The weird thing is that it reads correctly when tank is full.
Old Jul 10, 2012 | 01:59 PM
Doug18's Avatar
Yea it is odd I figure the sending unit is just bad I may replace it someday if I feel like wasting some cash ... and when I wrote this thread I was under the assumption that the fuel float was a hollow plastic one like I had seen on other vehicles not a foam one so a crack would not affect it. lll just count the miles like I did on my truck in HS would be sweet if I found someone that made a fuel consumption gauge like the ones they have for diesel that tells you exactly how many gallons you have used
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
raptor510
Aug 19, 2015 02:15 PM
horunner1x
Jul 10, 2015 06:33 AM
