- What would you do?
- noise in front driver's spindle.....
- part number lookup request
- Oil in intake and all over air filter!
- Lexus GX470 wheels
- Front locker/LSD suggestions
- Please Help - Door Lock Problem
- Tacomas near Addison IL- FREEBIE!
- PIC REQUEST: TJM T-17 w/hoop
- 2001 4Runner 4 wheel drive "cluck"
- transmission fluid leaking, sealant needed
- Brighter Luggage compartment light on 3rd gen runner
- Need instructions to replace liftgate struts....
- Thinking about a 00-02 4Runner Sport.. Questions...
- New 2000 4R Rear Window Wiper Blade?
- 2.7 hesitation?
- HVAC Control conversion: slide to dial?
- Increasing Steering Stiffness
- cornfed spacer/panhard rod question
- How to tell which gears??
- Plugs Wires
- Need help installing rear cargo cover on 96 4runner
- Rear sag on 100k mile 4Runner
- Coilovers - Donahoe vs. Camburg ????
- Rear window
- Hood Scoop
- Suspension lift spacers
- toyota service shop in cupertino? yarnell's?
- Want to lift your 3rd gen?
- '97 4runner lift options
- Alignment questions
- misfiring.. after rollin the runner
- do you think my front wheel alignment is off after I hit several potholes ?
- rough idle, after tearing the heads off
- TJM T-15 Torque specs
- Squeaking sound when starting truck....
- Need Some Suspension Advice
- Stiff gas pedal
- alternator trouble with supercharger
- Vortex muffler
- new here intake question
- When to replace timing belt for my 2001 4runner?
- Hitch Pics
- Manual Tranny Noise
- Largest light that fits on TJM-15 is ?
- Help mounting non stock fog lights to look stock 2001 4runner
- 3rd gen 4Runner engine problems
- PIAA fog light install question
- Tokico TrekMasters are on the way....
- Obd2
- 3rd gen 4runner rear brake issues
- 32s are on!
- 1996 4runner Steering Wheel Cover/Skin
- Wheelers Wheels - 16x8 4.5BS or 4BS??
- 1996 4Runner - Interior/Exterior Light Question (Dome, Map & 3rd Break Light)
- Fair price for '98 Ltd w/ lift?
- Lexus or Toyota Key Blank
- 1999 4runner's power locks are possessed!
- New Tires! but....calipers touching wheels
- VSC off, VSC Trac and CEL came on after putting in K & N Air Intake
- anybody have these rims on a 3rd gen?
- old man emu front strut problem
- Suggestions on 3rd Gen Upper Control Arms
- Infinity Kappa 60.5cs in 1998 4Runner?
- Better Taillights for a '98
- cross threaded spark plug
- how do you remove upper control arms? (ATS specifically)
- 2wd abilities
- Engine Mods??
- 98 Rebuild... it's alive
- Wiring short in tail lights
- Annoying squeek/rattle from rear
- Door lock Problem
- Need a rear axle for 99 4runner 2wd
- anyone near denver, co installed the urd kit?
- Downey Pro Desert kit
- 3rd G 4 Runner rear lift w/ LC coils
- ABS malfunction?
- Hesitaion under acceleration
- 98 4Runner steering gear dust boot...question
- Timing belt and its effect on fuel economy
- DoubleCab Burnout
- Anyone have any experience with mounting a T-17?
- '96-'99 front bumper fitting a 2001 4Runner
- Going back to stock, cut my sliders off......
- Big Tundra brakes on 3rd Gen 4runner
- ABS light on, driving on road, engine cuts...what gives?
- 99-02 4runner fog light pre-wiring
- 262 Degree Cams coming soon
- Free Inspection W/ Aaa!
- Camshaft service bolts.
- GL5 in transfer case (grinding)
- ProComp vs Alcan Add-a-Leaf
- Downey vs. PP (Ride Quality)
- all pro offroad leveling kit?
- TRD exhaust install in 2000 4Runner
- New GPS in 3rd gen (only a link to the thread)
- Vortex vs. Flowmaster - PLEASE HELP
- Those in cold climates, how's your heat?
- WRITEUP: 3rd gen TJM 17 install
- Well that was strange.....
- can't start the car
- 3rd gen hitch, Colorado
- new alternator for a 3rd gen
- S/C spark plugs
- What performance upgrade next?
- 1st Annual Texas Trails 4x4 Meet Sign-up
- Helper Leaf Springs
- Factory Foglights on a 1997 4Runner?
- Emissions gurus what does this mean (pic included)
- Flushing the Radiator - in progress
- Limited flares
- New Truck- Lost Traction and Noise from Dash
- Engine Idle
- 3.4 oil pressure
- 4x4 mode weirdness
- how do you change your transmission fluid the easy way ?
- Poor Mans Quick Disconnects?
- How many bulbs behind instrument cluster?....
- 1999 4Runner "Brighter rear lights"
- Keys for 2002 Tacoma
- Decided on 16x8 4" BS for 1999 tacoma..good choice?
- 97 Runner Rear heater control illumination?
- 3"front/2.5"back Spacer Lift Kits...What are the Pros and Cons to adding this mod
- Fuel Filter
- 02 sport skid plate
- 2002 Tacoma Used Billies
- Gas mileage too good, bigger tires should remedy ;) (wheel spacer Q's)
- 99 4runner "clunk" --> not zerk?
- Trd Tundra Lift Setup Problems For 97 4runner
- gas cap
- new OE sport hood! only $360 shipped
- Difference between 2WD and 4WD spring height
- Brake Drum Stuck - ?Damage
- NGK wire help ???
- Will 3rd Gen Daystar lift fit 99 tacoma?
- 2002 Tacoma Front Shocks
- Factory Recall on Fuel Tank
- Shifting problems
- Check out my 7" Panhard drop bar! :D
- Which brackets for 01 bumper to a 98?
- 4wd wont shift into the other modes
- My 99' 4runner rear ended
- removing rack endcaps (star socket)
- 98 4-Runner Rear window & wiper
- A little help with 97 SR5 and Axle Housing
- Pre-Body Lift Questions
- Poor Man's theft protection? What fuse do I pull?
- Online Service Manual for 97-2000 Toyota Trucks
- interchangeable 3rds
- Does Anyone know the front diff ratio for a 02 SE 4Runner?
- New Lift Idea
- Diff question
- Should I go to 35's !?
- 99 front valance swap onto 96-98?
- 1999 Limited w/ Heated Seats?
- Anyone here replaced their cigarette lighter?
- 2nd gen 3.4 trd s/c vs. 4th gen
- ashtray opens by itself
- 2000 4runner chirps like a bird.. (noise,help)
- ROOFGOOFS 1999 4RUNNER lift thread
- TJM Bull Bumper info?
- Looking Pictures of PIAA 60XT SERIES or other driving lights
- Parking brake light
- New VORTEX exhaust on my 2000 4Runner
- mud flaps
- KYB MonoMax front struts - gonna give'm a try...
- Removing my steering wheel
- 3.4 temps w/s/c urd fuel mods?
- New VORTEX muffler
- Headlight Wiring harness/diagram Question
- Lexus ES300 Fog lights?????
- 3.4 JBA Headers
- Is this a '99 Limited Wheel? (pic)
- i put my new wheels on
- What's your fav. type of spark plug for a 3.4?
- Cragar Soft 8 fitment issues...
- 99 4Runner Engine Light "ON"
- Which side is the tranny cooler return line?
- Anyon ever seen these hubcaps?
- When did 4Runners come with dual airbags?
- exploded diagram
- Sway bar Disconnects.
- replaced my shocks yesterday
- exploded diagram - control arms/shock area
- Same fog lights as sold on PP?
- Anyone know of this grille?
- picked up a set of wheels today
- 2001 Taco Bad Ping Problem
- weekend of wheelin and mod-buyin!
- Won't start - need help asap
- 3.4 Engine idle
- New P-U MANY Questions.
- 4th gen front diff retrofit to 3rd gen
- Disabling ABS?
- Un-Restrictive and Quiet Muffler?
- question about speedo/odometer
- Back in Style
- 285 in Spare - I searched
- Tacoma gears????
- Taco regearing
- light behind ac controls on 99 4runner
- 3rd Gen Front CV axle mod? Is it doable?
- Oh no, where do I go? (new forum displacement)
- What would make a catalytic converter go "bad"?
- swapping sliding heater control to rotary
- Airaid MIT
- 3rd gen bulbs
- New brakes and rotors
- Finally..Tacoma 285's on 17's and DVD...
- Tacoma rear axle size
- Custom Seats
- Pics Wanted: 3rd Gen 4Runner with Bushwacker Flares
- help me diagnose - control arm issues on my 96
- 2000 4runner check engine light
- Got pulled over -- What mudflaps fit rear?
- Rims / Tires Question (1997 4runner)
- Clutch Faliure 1996 SR5 3.4L
- Notchy, Rough Shifts
- 3rz bad valves!
- 165K+ miles and modding?
- Bridgestone Dueler Revos In Greensboro
- what are these wires?
- Question about Rhino lining bumpers?
- Clean inside of headlights?
- any pictures of oil filter and plug location?
- Hiya to everyone
- Has anyon ever removed their 3rd gen hood scoop?
- How should I mount my portable air compressor?
- Air Recirculate Vent Position 3rd Gen 4Runner
- HELP, power sterring belt
- i bought a 4runner
- Lift Problems...and then some
- Rewind seatbelt?
- 96 3.4 issues
- Can you put an elocker 3rd in a regular axle?
- 12v socket
- New wheels; new pics
- Ok, so my engine died on me.....
- bodylift+big rims+big tires= max size??
- How fast can you drive in 4wd
- *URGENT* New alignment specs for cornfed spacers
- Toyota Salvage Yards in AZ?
- Anyone know how much fuel a 4runner burns at idle?
- should I go with the Tundra brake or Brembo brakes ?
- How do I replace my 4wheel drive position switch ?
- I just had an Optima Red Top installed at Sears and realized it's the wrong model...
- 3rd gen Brake squeaking
- cheap fan controller
- Thermostat Acting Up?
