PIAA fog light install question
Old Dec 29, 2005 | 04:59 PM
SurfRunner98's Avatar
Question PIAA fog light install question
Hi everyone just got PIAA 540 fog lights and need to know what hot wire to hook the lights up too. Do i hook the wire to one of the three wires coming right from the headlights (it says hook them up to low beam) or somewhere else. This is the only thing stopping me from finishing the install. And is there a way not to hook the wire to the low beam light so i can turn them on without the low beams being on.
Old Dec 29, 2005 | 05:00 PM
Localmotion's Avatar
i just hooked mine to my parking lights. I think if u want to be able to turn them on at any time, just go back to the battery.
Old Dec 29, 2005 | 06:14 PM
thatll prob work and where is the parking light would it be coming out of the corner lamp housing
Old Dec 29, 2005 | 06:21 PM
yea..you can just splice into it.
I like to use this b/c its easy
soder would be best though
Old Dec 29, 2005 | 11:04 PM
ok thanks; it came with one of those. thatll be fun working in such a small area.
Old Dec 29, 2005 | 11:16 PM
Bob_98SR5's Avatar
always solder
Old Dec 30, 2005 | 05:31 AM
tc's Avatar
tc
Isn't there a relay setup?
You do NOT want to hook the power up to a small light wire - needs to go to the battery. These things draw quite a bit of power, and the voltage drop across the factory harness is considerable.
I hooked the relay up to constant hot at the battery, then the switch to switched power in the cab so they can be turned on without any lights and they turn off when the truck is off.
Old Dec 30, 2005 | 06:44 AM
It comes with a relay. There is a + and - wires that hook to the battery (about 12 gage). then a small remote wire to turn on the power switch. they say to hook that up to a 12 volt low beam wire thats where i didnt know what wire it was.
Old Dec 30, 2005 | 09:24 AM
tc's Avatar
tc
OK - gotcha. That's the wire I hooked up to switched power.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
