Thermostat Acting Up?
While driving in the icy Canadian winter, the last day or two I have noticed my temp gage will go up into the high & stay there for a while. Then out of the blue the gage will drop back down to normal & not move. My fluid levels are all good in the rad & spare tank. I think my thermostat needs replacing. Any other thoughts?
From: Far western Kentucky (transplanted from central PA)
What year and engine? Are you familiar with the headgasket recall on the late '80 thru early '90 V6's? Check your oil. Uusually you can tell if you're getting coolant in your crankcase by looking at the inside of your oil cap. What you described is a typical symptom of the headgasket problem. If your vehicle has not had the HG replaced, Toyota will do the repair at no charge, regardless of your mileage.
Here is the full scoop on the 2-valve t-stat that fixes the exact issue you are seeing:
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Went outside & checked coolant levels - they have gone down a little. I ran the vehicle with the rad cap off after topping it up to check for bubbling in the fluid. The exhaust is white, but seeing as it's -20C here right now, that's a bit of a poor test to see if I'm burning coolant. Would coolant levels dropping still be a symptom of a bad T-Stat or am I looking at a bigger problem (ie head gasket or worse?)
A cooling system pressure or chemical test would tell you if you have a cylinder to coolant passage leak:
- http://www.arrowheadradiator.com/hea..._leak_test.htm
kawazx636
Oct 6, 2021 03:03 PM
