New 2000 4R Rear Window Wiper Blade?
Old Jan 3, 2006 | 02:04 PM
jgs9455's Avatar
Question New 2000 4R Rear Window Wiper Blade?
I went to the auto parts store and got 2 new front wiper blades. They didn't have anything for the back window (even though they have ones for hatchbacks, etc.). Anyways I ordered the rear blade from Performance Products, and even though it is the right size (13") it doesn't appear to have the right mount. It has a multi mount that sort of works, but doesn't use the metal bumper to hold it off the window (the thing with two screws). Is the only place to get a new wiper blade from the dealer? Such a dumb question I know, but I can't find anything (used search) . Uggh.
Old Jan 3, 2006 | 03:02 PM
eric-the-red's Avatar
The only place I could find one for my 01 that fitted properly was the dealer. They only wanted $13 for it, not too bad.
Old Jan 3, 2006 | 05:54 PM
jodynich's Avatar
same here, not dice with napa, autozone or advance auto, ended up with dealer
Old Jan 3, 2006 | 05:59 PM
marko3xl3's Avatar
Yeah, same here, the rear is unique and you can only get the wiper at the dealer, and they are not too expensive either.
Just make sure not to use the extra little metal piece that comes with it, because the wiper won't work right if you put it in.
Old Jan 3, 2006 | 06:04 PM
bamachem's Avatar
you should have gotten the refills for the front at the dealer too.
they're the best you can get - seriously.
Old Jan 3, 2006 | 06:15 PM
marko3xl3's Avatar
Yeah, those ones they sell at Autozone like Bosch and whatever give up too fast. The only good ones I heard of lasting long are PIAA and OEM
Old Jan 3, 2006 | 07:45 PM
PO2SIMS's Avatar
I just recently replaced all three, and w/ the back I bought the cheapest one I could find and just took the rubber blade off the new one and inserted into the stock holder. Most rubber blades will fit in all holders. The back doesn't get used that much, so I don't see the need for a pricey one.
Old Jan 3, 2006 | 09:57 PM
jgs9455's Avatar
Thanks everyone!
Old Jan 4, 2006 | 03:51 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I've managed well by taking a refill in a larger size which has a hard plastic rail holding the runner blade, cutting it to the correct length (approx. 13") and melting the slot for the blade closed on the cut-end using a soldering iron to prevent the blade from slipping out of the channnel. It's worked well for me for over 13 years on both my '90 and '00 4Runners.
Old Jan 4, 2006 | 08:19 AM
Flamedx4's Avatar
Ditto.
Never could understand why people wanna replace the assembly when all they need is the blade...
Old Jan 7, 2006 | 04:42 AM
jgs9455's Avatar
http://directpartsconnection.com/
These guys had it for like $5.87 ($10 shipping though). It was under liftgate. They also had the rest of the arm and all the other little things if they need to be replaced (mine already has a little paint bubble [rust] on it).
ToyotaMD
Aug 17, 2018 10:16 PM
DeathCougar
Apr 1, 2018 11:29 PM
auscal
Sep 19, 2015 12:15 PM
justdifferentials
Sep 8, 2015 03:13 PM
AkitaDog
Sep 3, 2015 09:01 PM
