- Doh ! $%*!ing timing belt marks !!!
- Squeaking ES bushings - normal?
- Any one use coil wraps ????
- CSI or battery?
- Hood protector for 3rd gen
- 22r carb help!
- muffler sound
- Need Skid plate bolt....size?
- heating and cooling issues
- 87 4Runner rear window relay mind of its own
- Airaid MIT for $15, nah couldn't be
- Symptom of a bad starter?
- New shift bushing & seat = smooth shifting
- Call out for engine bay pics!
- '96 3.4 Check Engine Light...
- Rattle in dash
- website redesign
- I'm now a Toyota Fan
- Need info for ATF change
- Battery Question
- Hood Scoop
- 1990 4runner gets new guts
- Oil Light Flicker
- OK let me introduce myself. scout2 convert!
- Starter Relay Replacement??
- Advanced Timing Code 52 Question
- #2 idler pulley (timing belt) nightmare.
- Not so great Optima 34R experience - advice anyone?
- Sevice manuals which one
- tacoma throttle body question
- SCION HU Going in 3rd gen Tacoma
- 3rd gen short shifter kits
- replacing transmission pan GASKET.
- New Head Gasket new rattle???
- First modifications completed (pics)
- 02 taco brake problem
- 3WD?--wheel lock mystery?
- looking to buy a 4runner
- Radio Reception
- E-Brake Light stays on
- TJM-15 model 96-98/S1586Y and 99-02/S1586W
- Are these springs stock. Picture inside
- What bulb for IPF's on ARB Sahara?
- Is it normal to hear a slight whine in the transfer case?
- Anyone Replaced Their Dash Pad (91 4Runner) ?
- Transmission Cooler???
- Rear Axle Swap To Factory Locker
- New Member, New 4R on the way
- New Shocks for 4Runner --- which ones?
- how to remove the 5spd shift knob
- Leaking Transfer Case
- 2002 4Runner differential
- have you ever seen this rack before?
- 2001 3.4 misfire in the morning
- Good Maglight mounting spot in extra cab tacoma
- 1992 4-Runner Hard Starter Help!
- 90 4runner Front Axle Replacement
- Wet Okoles for 3rd gen (Informal Review)
- Two questions for an electrical genius...
- TJM Question
- 2002 Tacoma engine proble
- Needed....00 to 02 Limited
- weird idle
- Performance Products Rims
- 88 4-run Auto Trans
- Replacement rear springs
- check engine light
- Decent Ebay find
- Magnaflow Cat Question
- WHEELIN' and DEALIN' for tires and wheels
- 1984 sr5 HB 4x4
- Fitting 35's on a 3rd gen without going sky-high.
- Wiper and washer problems
- 24's on a 3rd Gen....Yikes.
- Strange Wiring Problem with headlamps
- what is the 4Runner "Air to fuel ratio heater Bank 1 Sensor 1"
- 250mi away from the big 200k! 200k club.
- 94m 4 Runner OBD II code reader needed
- 01 Tundra CEL, what else could it be?
- Code 52 94 4Runner runs great
- My first yota / more effiective use of seafoam
- Will this tire size fit 3rd gen?
- Gas Milege - o2 sensor and other stuff
- tire size question
- Break check light?
- Clutch Bleeding
- 4runner questions
- Snow between Cab and cap
- Will frt & rear 3rds inerchange
- 5th gear noise in 89 4cyl 4x4
- Fuel pump on an 86 4Runner
- Blowing Fuses??
- 1990 4Runner starting trouble
- simple question for 2" lift, ps, i already searched
- What would you do if you just got an '85 4Runner?
- Eibach springs for 2nd gen
- 200,000+ mi. Hawaii club
- '87 Runner possible alternator/eletrical problems--PLEASE HELP
- Flowmaster or Vortex Cherry Bomb
- Issue with Bosch Platinums and Coil pack ignitions
- 96runner Tailgate
- front diff breather (3rd gen)
- Battery Tender
- 22re max PSI boost?
- water in my oil
- Tranny cooler hose question
- wiring assistance please...
- floated tacoma now has no power help!
- Help from anyone that has taken out a 3.0
- vacumm lines
- Speedo Cable- Please Describe The Noise
- Toyota Truck/4Runner story in 4WheelParts mag.
- Is this a good deal? Looking at a used high-mileage 3rd Gen.
- Wifies' 4runner
- Non electric speedo on a 95
- Power steering assist hoses
- Garage cleanout, tons of stuff for sale.
- gear prices
- URGENT-Tire fitment
- 2003 SVT Ford Focus VS 1995 lifted 4Runner
- 2nd Gen 4runner 4wd problem...
- Tail lights?
- 2nd gen & snow/ice
- What would you pay?
- Thinking of buying a 93 4-Runner Help Please
- Shifting Between 2WD & 4WD in 89 4Runner
- Knock sensor effects on driveability
- OEM Filter for A340F tranny - Part Number?
- Downey-offroad CV boots for 3rd gen 4Runner
- head gasket?
- Help with 90 4RUNNER V6 alternator
- Sticker striping on 95runner
- Alternator/Brushes
- So, is Toyota listening? 4wd to 4x4 on mudflaps?
- exhuast
- My fathers truck runs till he cuts it off
- I just bought a 3rd Gen
- HELP adding seafoam to 2.7l pcv valve
- what to tap for autometer gauge lights??
- Are cranks ID'd when machined(-01,-02)
- '91 4runner roof rack mounting
- Downey header install hitting frame (3.4L swap) help
- 1984 Toyota Pickup 4WD rust problem
- 2nd Gen Instrument Cluster Question
- Toyota Tacoma Tonneau Cover w/Bedliner
- Fender Flare Suggestions
- Rear end clank ??
- Do I need to resurface drums with new brake shoes?
- 3" lift shock question
- belt snapped, quick question
- What are the odds my motors toast? Hydrolock
- 954runner Keep it or sell it
- HELP loud winding noise in instrument panel (Dash) HELLA ANNOYING
- 3VZE timing belt.. which idlers did you replace ?
- 285s not fitting
- Service Engine Light???
- Brake System Warning Light
- Alternator Insta-Death? '82 4x4
- How much can the stock tire carrier take?
- Need all the DIY FAQ's on brakes
- Rear Oil Seal
- Anti Knock
- Tranny Trouble
- Oil light Trouble
- My truck just started running like crap!
- Few basic questions on a 83 toy p/u
- trying to fix a wreck
- 32's on stock truck
- Drive Shaft q's
- Head GAsket symptoms...
- 2nd Gen 4Runner Tail light options?
- 89-95 toyota pickup rear drive shaft
- gas smell - don't where or how
- 3rd Gen --STALLING-- When Warm?
- Help identifying these relays?
- 3.4 swapped 2nd Gen 4runner *pics*
- body lift ?
- stainless steel pipe question
- 2005 Tacoma: First year quirks?
- E-Brake Light
- Desperate for 4wd Help!
- Will this kill my battery?
- 22re miss at idle.
- Can stock rear bumper handle hi-lift?
- Locking fuel door
- 91 4Runner 22RE Starts but wont stay running. PLEASE HELP!
- Hypothetical? Why hasn't this been done?
- air intake chamber
- Weathertech Floorliners
- Help!!! 2nd headlight bulb
- 90-95 engines and models
- vibration and now chirping sound
- Installed-Raingler Rear Cargo Barrier
- Foamy Diff Oil ???
- Which yota to pick
- Auto Lite Spark plug wires
- surco rack retailer & product fit and opinions - 3rd gen 4runner
- All Season Floormats....
- Help with my 90 Yota 4Runner?
- 22RE Idle Issue
- grrrr windshield washer light
- 00 4runner wheels lock after full braking
- I am looking for a rear steel bumper for 3rd Gen ?
- '89 exhaust manifolds on 1987 toyota
- no 4hi, but 4lo works
- aftermarket rear latch?
- 2nd gen driver window grinding??
- '90 Rear window relay, why does it beep?
- ADDCO front stabilizer bar (3rd gen) - what's the stiffened angle bar for?
- Thank You
- Looking for a 3rd Gen near San Francisco
- setting up a road tripper
- 94 pickup tailgate ?
- 4wd issues
- 3.0 to 3.4?
- Who needs ARB bumper?
- 22re clatter
- Dip Stick
- All Pro rear bumper on
- headers or not?
- Trailmaster SSV Shocks
- Common tire sizes?
- Pinion Seal?
- What to do with the front flooring of a 4Runner/why is it leaking?
- Strange Drivetrain Noise
- Shock Help
- Coolant Flush questions
- cruise control not working...clutch bushing?
- No Pressure in Clutch Pedal
- Bilstein 5100 bushing FYI
- HELP ASAP, Drving w/ no front axel???
- alternator amp output ?
- PO420 @ 87k on v6
- Shopping for a late model 4Runner
- Paint job needed, any body shop recommendations in the MD, VA, PA WV area?
- Check Engine light come on after oil change never done it before. help
- Speed density 3.0 mod, no AFM, no Mass air
- Turkey Day HELP?
- Feeler: 3.4L TURBO manifold group buy?
- 1999 4Runner washer reservoir volume
- Speedo NFG
- 2000 4runner (3rd gen) starter replacement
- Fuel Tank Inlet
- Parts for new Taco
- Singing 4runner
- 2000 4Runner Headlights: Switched Ground or Switched Power?
- Bed in rear of 1st gen runner?
- 1st gen, 3.0L 4runner washer fluid question
- clutch squeak NOT BUSHING
- Swap 4th gen Land Cruiser Disc on 3rd gen 4runner
