URGENT-Tire fitment
Old Nov 30, 2005 | 10:14 AM
TinyTruck's Avatar
URGENT-Tire fitment
Will a 32x11.5 bfg all-terrain mounted on rims that came off of a 88 pickup fit on a STOCK 1994 4-runner 4x4 WITH NO RUBBING
Old Nov 30, 2005 | 10:15 AM
colsoncj's Avatar
maybe... what kind of rim and do you take it off road?
Old Nov 30, 2005 | 10:19 AM
TinyTruck's Avatar
regular 88 steel rim and this thing does not wheel it just has to go from lock to lock and not rub
Old Nov 30, 2005 | 02:08 PM
TinyTruck's Avatar
ttt..
Old Nov 30, 2005 | 03:51 PM
colsoncj's Avatar
I would think so, but not sure.... under full compression I would say it would rub, but again, not sure.
Old Nov 30, 2005 | 05:45 PM
4inspeed's Avatar
they will most likely rub, depending on a few things... i know some people have put them on stock and havent rubbed.
but depending on the place your getting them from they should do a "test fit" for you. have them throw the tires on and run it lock to lock.
And i know that the bfg at ko is one of the "wider" at tires out there, i just test fit a set of 32 muds on my 91 runner and no rub, but if i was turning and hit a bump i would have issues.
Old Nov 30, 2005 | 05:57 PM
Brendan's Avatar
i don't think they would rub. 31s don't and there's gotta be more than 1" of clearance. it will depend on the backspacing of the wheel also. if they used the same backspacing in 88 and 94, you should be fine.
Old Nov 30, 2005 | 06:17 PM
BeaterToyota's Avatar
Depends. Vehicles come from the factory with various heights cranked into the front torsion bars, and the rear springs will sag differently on one rig than they will on another.
My '88 and '94 trucks both came stock with 225/75/15 tires. Right now I have a tall set of 32" Swampers on the '88 truck and they fit fine, but my '94 truck is much lower and I'm sure they would rub. With my rigs parked next to each other there is huge height difference.
Old Nov 30, 2005 | 07:57 PM
s_wall98's Avatar
Dont think they will. I had 32x11.50 Yokos on Sr5 rims on my 94 and it was fine. On full lock there might have been a bit of rubbing but not enough for me to do anything about. Drove it for about 6 months with no problem. The only thing i can see as maybe being trouble is the front valence....no problem with that if you have a dremel though.
kawazx636
Oct 6, 2021 03:03 PM
Ritzy4Runner
10
Jan 14, 2012 07:11 PM
deputydawg
Nov 13, 2006 09:58 PM
DeathCougar
Sep 20, 2006 04:41 PM
DeathCougar
Apr 29, 2006 11:44 AM
