22r carb help!
Old Dec 5, 2005 | 04:16 PM
knottshawk's Avatar
22r carb help!
I've got a 90 pu with the 22r. It's been stumbling occasionally when driving a consistent speed. So, I put some higher octane fuel in it to see what would happen. Well, it seems worse now. So, I popped off the air cleaner and, well, pardon my ignorance (I'm used to 4 bbl carbs), but this thing seems to have one jet and 2 intakes? Is that right? Anyways, the intake, without the jet in it, is mostly closed (butterfly valve) even when warmed up.
SO, all that to say: Is this a vacuum problem? Is this valve run by the EGR? I need ideas here... thanks in advance.
Old Dec 5, 2005 | 04:17 PM
Elton's Avatar
did you search ?
Old Dec 5, 2005 | 04:19 PM
knottshawk's Avatar
Search for what? "What's that carb part?"
I mean seriously.... Isn't my question(s) a little too nebulus for that?
Old Dec 5, 2005 | 04:42 PM
tc's Avatar
tc
Try Seafoam or other carb/injector cleaner?
Electric choke on these IIRC.
When mine started doing that, I just replaced it with a Weber 32/36 and never looked back.
Old Dec 5, 2005 | 04:44 PM
knottshawk's Avatar
So is that second butterfly valve supposed to be shut even after warming up?
Old Dec 5, 2005 | 04:46 PM
86toyota's Avatar
No. Only closed on warmup
Old Dec 5, 2005 | 04:51 PM
knottshawk's Avatar
Um, by "on warmup", do you mean while warming up? Or after the truck is warmed up?
Old Dec 5, 2005 | 05:00 PM
86toyota's Avatar
While warming up. On a cold engine after you turn on the key(not cranking yet),you should step on the throttle fully a couple times. That should close the choke fully, then start it up. the truck should run at high idle for maybe 2-5 minutes then kick down automactically, opening the choke butterfly.
Sounds like your choke isn't working correctly.
Old Dec 5, 2005 | 05:01 PM
86toyota's Avatar
I didn't know they still used carbs on 90's???
Old Dec 5, 2005 | 06:07 PM
kyle_22r's Avatar
2wds were available carbed until '90 or '91
on a lot of the carbs, the secondary choke flap stays shut until you mash the throttle. that's why putting on a weber 32/36 often increases performance, since the carb isn't operating at full potential.
if your engine is stumbling at constant speed i might check the EGR system to make sure it's functioning properly.
Old Dec 5, 2005 | 06:43 PM
knottshawk's Avatar
Where is the EGR on these things? A buddy of mine said to just disconnect the EGR and see how it runs after that...
Old Dec 5, 2005 | 08:42 PM
kyle_22r's Avatar
EGR is the little gadget next to the intake manifold towards the back of the engine.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
