Help with 90 4RUNNER V6 alternator
Old Nov 29, 2005 | 10:56 PM
Slowrunner's Avatar
How does one go about getting it out of the engine bay? I changed an alternator before by just un-doing the bolts and connections but this looks like its stuck in there.Whats the trick.
Old Nov 30, 2005 | 04:17 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
If I recall from when I had my '90 4Runner 3.sl0w, there was no trick. I don't think it was any different then replacing an alternator in a domestic (other than almost busting the electrical connector).
Old Nov 30, 2005 | 04:43 AM
Slowrunner's Avatar
What other parts have to be removed to pull the alternator out? Does it come out the wheel-well, or do I remove the air box and or other crap?
Old Nov 30, 2005 | 05:31 AM
Churnd's Avatar
There's a bolt on the top, then an adjuster bolt on the bottom. Remove the bottom one first to get it loose and slide the belt off, then remove the one on the top. From there, you can shimmy it out towards the radiator. Now that I think about it, I had the electric fan on mine and the shroud removed, so that might've helped me. If anything, just remove the air intake tubing and you should be able to get it out that way.
Old Nov 30, 2005 | 05:37 AM
Slowrunner's Avatar
Ya after using the search button I found that removing the air box is the way to go. I will find out soon enough.
Old Nov 30, 2005 | 09:01 AM
mikes4Runner's Avatar
Yes remove the air box/tube and it comes out just fine.
easy
Mike
Old Nov 30, 2005 | 11:48 AM
Slowrunner's Avatar
It was easy. Took me 2 hours although.(hard to find the bolts I dropped in the snow)The cabin air cleaner box and another box under it had to be removed but the actual air filter box stayed. Got a used alternator from the wrecker for $125. The old one was saturated in engine oil from the distributor (Probably why it was failing), but I will keep it and try to rebuild it case.
Old Nov 30, 2005 | 01:55 PM
Babypig's Avatar
Please tell me you didn't end up going to Alpi's. Those guys are the biggest ripoff artists around. Cambodian tire sells rebuilt alts for not too much more. The brushes are only 13 bucks from toyota as well and can be replaced in 10 or 20 minutes.
Old Nov 30, 2005 | 07:15 PM
YotaJunky's Avatar
If not Alpi's which wreckers in the lower mainland would you recommend for used 4runner parts? I was actually thinking about going down there to look around during the weekdays, because they're not open during weekends.
Troy
Old Nov 30, 2005 | 10:58 PM
Slowrunner's Avatar
A-combined in Abbotsford(lots of 4runner parts). Canadian Tire was $187 exchanged and did not carry them in stock.They said 3 days.Napa was $200.,and Lordco with my discount $300+.Ya right.
Old Dec 2, 2005 | 06:00 AM
Babypig's Avatar
Ralphs,, there is another one that is near there as well. Down the street and the first right. I only say that Alpi's are crooks cause they are. Makes the prices up in his head and changes from moment to moment.
Chicken12
Oct 14, 2015 03:54 PM
scheuvront1993
Sep 17, 2015 06:17 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
izzmee
Aug 17, 2015 10:20 AM
tdsmith8
Aug 11, 2015 10:09 AM
