Will this kill my battery?
Old Nov 27, 2005 | 12:53 PM
MarkieMark's Avatar
Well my friend broke my antenna yesterday. Now my antenna won't go completely up. It makes the motor noise. And to put the antenna down i have to push it about 4 inchies till it will go down by itself. Until i replace my antenna would leaving it all the way up kill my battery? I just want to make sure.
Old Nov 27, 2005 | 01:29 PM
marko3xl3's Avatar
Nope, it uses a mechanical latch to stay up.
Old Nov 27, 2005 | 02:01 PM
mach4's Avatar
You might want to remove the mast asap before the teeth break off inside of the antenna motor.
It's not a big deal if that does happen but you'll have to take the antenna motor apart. Don't ask me how I know.
Just remove the nut on top with a screwdriver or long nose pliers.
Turn your radio ON, and as the motor works to push up the antenna pull it all the way out.
Then you can order a new mast or go with the favorite taco whip mod in this forum.
Old Nov 27, 2005 | 02:28 PM
Tragic Drive's Avatar
Antenna mast Have your friend give you a $20 spot and order a mast from here. If your geared nylon cord is broken you might have to remove the little motor in the fender well to replace it.
Good luck, Thomas
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
Gone Fission
Oct 7, 2015 12:42 PM
mreagen
Oct 5, 2015 04:27 PM
JPV
Sep 28, 2015 03:15 PM
