Will frt & rear 3rds inerchange
Old Dec 1, 2005 | 03:16 PM
MRIROK's Avatar
I have frt & rear 3rd members out of the howsing from a 85 pickup not shore witch 1 is the front or rear how do i tell or is there a defference THANKS
Old Dec 1, 2005 | 03:18 PM
seaflea's Avatar
they will interchange.
Welcome to YT
Old Dec 1, 2005 | 03:29 PM
MRIROK's Avatar
THANKS So will a locker that came from a rear go in the frt? I want to put a spool in the rear & a locker in the frt & I have a powertrac out of a rear I was hoping to usein the frt.
Old Dec 1, 2005 | 03:32 PM
seaflea's Avatar
Yes it will also fit.
I am assuming you are putting these 3rds in a solid axle truck. Is that correct?
Old Dec 1, 2005 | 03:33 PM
4Crawler's Avatar
Generally lockers and limited slips will swap no problems. Only one that may be an issue is the TrueTrac that is supposed to have different units for front and rear axle use.
Old Dec 1, 2005 | 03:47 PM
MRIROK's Avatar
yes solid axles but there going In a sammy
spool the rear & probly go with a aussie locker in the frt if the powertrac will not work.
Old Dec 1, 2005 | 03:50 PM
seaflea's Avatar
sounds like you are building a nice little tough rig.
post up some pics of it.......
Old Dec 1, 2005 | 03:59 PM
MRIROK's Avatar
Ill dig some up .I still have the sammy axles under it till I have all parts together .at the momet im running 462 in the diffs 4.1 t/case yj missing links frt 1/4 eliptic 4 link rear with 33 tsl,s in a 88 tintop but iv got a set of 36 Irocs on beadlocks to go on & im doing good to run 33s with the sammy axles so its time to step up to toy,s& 100 inch wheelbase
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
