New Head Gasket new rattle???
Old Dec 4, 2005 | 06:03 PM
hi-desRunner's Avatar
okay so i got this 4runner for 200 bucks went got the heads shaved and installed the new head gasket, okay after i got the timing right i started it up and i have this nasty rattle coming from the engine bay before the new head gasket it didnt have that rattle? it blows smoke like crazy too, when the heads were off i checked the pistons and they seemed fine no excessive wear or nothing so do inow need to get new heads??? or does it sound like timing belt rattle??? i didnt change the belt because it looked new but now im thinking i gonna change that to see if it will help. could getting the heads shaved caused this problem??? thanks for all input
Old Dec 4, 2005 | 06:48 PM
to the top
Old Dec 4, 2005 | 07:10 PM
Babypig's Avatar
What kinda rattle? Top end sounding or bottom end clanking? What color smoke? V6 right?
Old Dec 4, 2005 | 09:11 PM
yeah top end rattle weird thing it didnt make no noise when it had the head gasket blown??? white smoke and all? it's still blowing white smoke
Old Dec 5, 2005 | 04:22 AM
ThomasJ's Avatar
Could be a cracked block or head. Or you didnt get the head gaskets sealed up good. Do a leakdown test to determine what cylinder/s are the problem.
I would not bother with the timing belt untill you figure out why it is burning coolant.
Old Dec 6, 2005 | 08:27 PM
node's Avatar
Does it continue to smoke if you let it run? Every timing belt job I have ever done has had coolent in everything and takes about a min to clear up. Shaving the head could have made your engine interfearence Did you turn the cam while the belt wansnt hooked up? On toyota engines for some readson when you change timing belts the tensioner pully will go bad at the same time. Dont know why but thats something to check too.
Good luck
Old Dec 6, 2005 | 11:24 PM
Flamedx4's Avatar
Did you count your wrenches and sockets when you were done?
Old Dec 7, 2005 | 07:29 PM
node's Avatar
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
