Pinion Seal?
Old Nov 25, 2005 | 12:56 PM
surelly09's Avatar
Pinion Seal?
OK I have a 1988 toyota V6. I noticed the pinion seal leaking about 4 weeks ago so i put off replacing it until i changed the gears out to 4.88's. I replaced the seal when I replaced and well everything is was great until i made about a 10 minute ride on the expressway and when i got out of the truck i noticed the it was seaping again. I was wondering if anyone else has the same problem... I noticed there is a slight vibration in the rear and i was wondering if maybe an out of balance drive shaft would cause the same problem. Another thing to note is that i have 2" lift shackles on the rear which changes the angle of the whole assembly in relation to the transmission. Just wondering if anyone has any ideas as to what the problem could be and a possible solution. Thanks
Old Nov 25, 2005 | 01:08 PM
superjoe83's Avatar
was there a large groove on the flange where the seal rides?
Old Nov 25, 2005 | 01:18 PM
surelly09's Avatar
nope... everything was in great shape!!! even the pinion seal looked good.
Old Nov 25, 2005 | 05:15 PM
superjoe83's Avatar
pinion bearings still tight? theres not much more to go wrong, maybe you got a defective seal?
Old Nov 25, 2005 | 05:56 PM
surelly09's Avatar
could be a bad seal i guess... yeah the bearing are all still tight... its really wierd... thats whay i thought that maybe the drive shaft has become unbalanced and maybe the slight vibrations allow it to leak... thanks for your help
Old Nov 25, 2005 | 06:08 PM
kyle_22r's Avatar
a bad case of the vibes can definitely fry a pinion seal, as well as pinion bearings on their way out.
Old Nov 25, 2005 | 06:17 PM
surelly09's Avatar
well the pinion bearings are brand new!!! so i don't think its them... guess i need to find a place to get my drive shaft balanced!!!! and a new pinion seal!!!
Old Nov 25, 2005 | 06:18 PM
86toyota's Avatar
Don't they make a sleeve N seal for the pinion. Might want to try that.
Old Nov 25, 2005 | 06:20 PM
surelly09's Avatar
well i used the crush sleeve eliminator but i have never heard of what yer talking about... could you elaborate?
Old Nov 25, 2005 | 06:52 PM
kyle_22r's Avatar
he's talking about a repair sleeve. it's a really thin metal sleeve that you drive onto the seal surface, effectively creating a new surface for the seal to ride on.
Old Nov 25, 2005 | 06:58 PM
86toyota's Avatar
I know they have one for the front and rear crank, but I thought they had one for the pinion flanges. I've been researching but came up with nothing yet. I swear Fel-Pro made one.
A vibration will cause a new seal with a good seat to leak thou. Might be a bearing issue.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
