Pinion Seal?
Pinion Seal?
OK I have a 1988 toyota V6. I noticed the pinion seal leaking about 4 weeks ago so i put off replacing it until i changed the gears out to 4.88's. I replaced the seal when I replaced and well everything is was great until i made about a 10 minute ride on the expressway and when i got out of the truck i noticed the it was seaping again. I was wondering if anyone else has the same problem... I noticed there is a slight vibration in the rear and i was wondering if maybe an out of balance drive shaft would cause the same problem. Another thing to note is that i have 2" lift shackles on the rear which changes the angle of the whole assembly in relation to the transmission. Just wondering if anyone has any ideas as to what the problem could be and a possible solution. Thanks
Originally Posted by surelly09
nope... everything was in great shape!!! even the pinion seal looked good.
could be a bad seal i guess... yeah the bearing are all still tight... its really wierd... thats whay i thought that maybe the drive shaft has become unbalanced and maybe the slight vibrations allow it to leak... thanks for your help
I know they have one for the front and rear crank, but I thought they had one for the pinion flanges. I've been researching but came up with nothing yet. I swear Fel-Pro made one.
A vibration will cause a new seal with a good seat to leak thou. Might be a bearing issue.
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
