- Trade 265/70/16 Nitto's
- Synthetic diff. fluid
- OEM +TRD Suspension Q's
- Do we have any members of LHWC here? (56k...click, fab up a bumper, then check back)
- 3.4 Rev Limit?
- 98 4runner rotors
- cruise control=sporadic
- Inner tire wear
- 98 4runner oil leak 3.4L
- Help! OEM Fog Lamp Install
- Need to add .75" on my 99 4Runner
- elocker motor
- Tundra OEM lift Q?
- Tranny coolers.......standard on 2000 4runners?
- Question for S/C'd 4Runner owners in LA
- Gear shift rattle
- steering problem...
- Hand pump Oil Extractor
- Will 20inch rim/tires fit my 97 4runner ?
- Should I replace my throttle body?
- 05+ tacoma shocks on 3rd gen
- Pics of Sport Edition w/out running boards?
- What guages and where to put them??
- more about clear corners
- O2 Sensor
- Opinons from 4.56 w/ 285,295,305 users
- clutch stutters or chatters
- Tundra brakes & SS brake lines on my 4Runner
- Ac Pump
- Will regular work well?
- A/C feels weak - '01 4Runner
- Mysterious Wire
- These TRD rims on black truck...
- crunching sound in front end. help!
- 2.7 Exhaust Manifold Driving me Crazy!
- 99 tacoma 2" lift and standard shocks
- add a leaf or block?
- Finally got some pics of my ride!!!
- URGENT! Help with Brakes.
- 3rd Gen Dash Rattle - Going Nuts!
- OME 3" Installed
- should i buy a new 4runner?
- Chevron Fuel Injector Cleaner Question
- Need some opinions w/ brake problems
- Lower gear ratio with same size tires
- Bump Stops Replacement
- my conclusion on a lift for me!!
- 4.5L V-8 vs. SC'd 3.4L
- Dilemma mounting lights
- rear end ?s
- Exhaust and Brakes
- FJ 80 wheel lugs
- Remanufactured OEM E-Lockers?
- 97 runner
- Where can i get TRD struts??
- Air Lift 1000 Installed!
- Tires, after lift D:
- Any service experience in the Milwaukee area?
- Slicks's Runner Finally *for sale*
- Intermittnt idle problems on start up w/5VZFE
- top plate spacer and studs for Tundra coil swap
- Gauging interest: 3.4L Phenolic Spacer Kits
- Would it even be worth it for me to mod my truck up?
- Timing belt and water pump replacement
- Tundra brakes on today!
- 2002 alternator
- Exhaust Setup options
- 15" Rim fitment on '98 4Runner
- 2.4 Liter Low Idle
- ISR mod, one week later...
- Empty Campus=Good photo shoot, trouble with cops
- How do you re-clock a MM PE8000 winch?
- 22.12
- Is breaking rear axle mounts a common problem?
- Windows Radio as Gauges
- 5vze changes?
- Fog light help please
- Finally a formal greeting with pics...
- 2nd owner, whats with my air intake?
- Changing coolant
- cigarette lighter problems
- New Flowmaster
- Hot start stall problem...fixed!
- 97 3.4 auto non-trd locker question
- IC8, Lunar Mist Paint
- look what my dumb idiot self went and bought
- Spark Plugs on 2.4
- New (Used) Tires and a quick photoshoot in Gilbert, AZ
- Roof Rack for the stock rails?
- Looking for rear axle shafts for a '96 4runner??? Any websites???
- 99' Coils and KYB Monomaxs installed
- Need Tacoma Advice
- Rear Diff locker seized? plus more?
- wiring
- Removing Limited Fender Flares ALL
- Rear axle is falling apart and I need help on coming up with a plan of action
- ADD to non-ADD Diff Conversion?
- Tire trade ins?
- Tire tread problem
- Mickey Thompson Baja MTZ's
- build a bumper
- Turbo 99 4Runner Pics - 5vz-fe
- Wheel Question
- Did all Highlanders come with Rear Lockers?
- Tire Valve Replacment
- How long did it take to get your True Flow?
- Would this be similar to the deck plate mod?
- Power Door Locks not going down-
- Any 4runners using Donahoe REAR springs and shocks?
- TT lift help please, I even searched!
- Help with 98 4runner pricing please!
- abs codes
- Curt Trailer Hitch for 4Runner
- Battery, Battery, which one to pick...
- Oxygen Sensor...Just heard a rumor
- What struts?
- Just A Few More Mods
- toytec ques
- Misc Bushing Upgrades
- p0136 error solutions?
- bamachem spacer
- Auxillery Fuel Cell 2002 4Runner
- this seems weird to me....
- Couple questions (OME)....I searched I swear!
- Color Code on 99 springs
- katzkins installation
- Tundra brake conversion... which rotors???
- 4runner soon... OEM lift?
- Relacing timing belt...do I need to discharge AC system?
- Is this a good deal on used 285s, and will I have any issues on my 16X7JJ rims?
- 2in RB BL finally installed (lot's of pics)
- My new truck!
- LC Coils Front?
- 4runner sleeping platform!
- EMU Coils / Bilstein Shocks
- nedd to replace zerk fitting
- hole in CV boot
- New guy, unsolvable problem
- Stock priming pump
- Help picking lift
- 98 4runner relocating AC controls lower in the console
- which katzins fit?
- anyone have the problem fix itselfs?
- rust in the cooling system
- power antenna broken
- HELP with DRL mod!!
- Newbie...Again - 99 Suspension / Brake Qs?
- DoubleCab Taco in need of OME 881 or 882? Help
- Window stone chip !
- Mystery smell, invisible fluid?
- Suspension and brake problems, advice please.
- Ideas? sensor fail????
- Do your trucks/4runners wander?
- lift in progress
- Rattle in the headliner...
- For Sale: 97 4Runner SR5 4WD
- Guess what i found...
- Can tire Tires
- Little Weekend Maint---
- 4runner weight
- 97 Tacoma shock issue...
- Pic request
- 02 Brushguard
- stinky transmission
- Buying and Engine - What to Look For
- tundra struts and springs on 3rd gen 4runner
- Inner Tie Rods
- Hood lifts finally available for 4Runner and Taco's
- Brake Problems (Left-Rear tire locking up under braking)
- HELP! about a 60 -70 % power loss 97 4runner
- new rims and tires
- 20 deg RTI Ramp Fun with my '97 4Runner and SS Lift System 7.1
- Help identify this?
- 97 runner headlght lens
- 3rd Gen hood scoop into 2nd Gen
- clear corners
- Airlift 1000 vs. Firestone air rite
- Steering rack
- Help with differential question
- My 4Runner jumps up & down at low speed
- Starting Trouble
- Brushguard
- Floor Mat
- Inner Tie Rod
- Tool Box
- 4runner GUN TURRET
- Weatherstripping replacement?
- crazy flex pics.. 3 wheels on ground
- Check out the threads
- FS: Almost new 265/75/16 REVOs
- Finally Got My First Toyota
- Paint Chipping
- Converter for trailer install question
- Idle problem
- Whats the best rotor/brake set up?
- Rear Differential Leaking Oil and Making Grinding Noise????
- 99 Springs + 2.5" Daystars Front Suspension?
- Question on "Type R" Diff Breather Mod
- custom gun/bow platform for my runner
- Possible or not 4runner experts??
- Tranny problem...?
- Slip yoke findings
- Odd Question
- Axle shaft bent?
- Cheap OBD 2 Laptop Software?
- Might buy a Tacoma
- SAW 2.0 rebuild manual?
- best 3rd gen clutch???
- Big concerns with my front suspension ? Please Help.
- Installing a Power antenna???
- Looking for a Good Aligment Guy Austin
- Trailer Light Converter Question
- Manual Hub Conversion...
- AirBag Warning Light
- Exhaust Systems?
- 231mm Tundra Caliper Question
- Direct fit catalytic converter.
- Pic Request: OME 3" front + LC Rear
- PO171-1999 4runner
- Just noticed this after body lift, is it normal?
- Fuel leak! Did anyone repalce this hose yet?
- Im A Moron!!!!
- weird starter problem
- "Pin" removal Front Brakes? 2000 4runner
- A few post-OME installation pics...
- Mixing Springs
- 274/70 R16 fit stock height 3rd gen 4Runner?
- How do you rewind TUNDRA ODO?
- Installed OME Frt Suspension Today
- my 2001 4Runner ... finally something to show
- apexi safc II wiring diagram
- Spring/Shock Recommendations...
- Pics of lift and tires
- finished stereo install
- Blower Resistor
- Please Help! - 5VZFE Engine Owners
- Loud humming sound after 4x4 swap
- Fan blades broke
- Rotor removal on a 1999 4 Runner
- 3.4 Fuel pressure drain back. Fuel sys?
- Hard Start
- Bilstein 5125's: Valving & Length?
- speed vs. mileage
- All the Mods that can be done to a 3rd gen 4runner. Contest! Who knows the most?
- lund avenger bug guard
- Sport Edition owners - Pic Request
- Is this 2000 runner worth it?
- Smitty Nerf's Install
- emergency brake light wont shut off after lift install.
- No luck finding calipers today :(
