Rotor removal on a 1999 4 Runner
Old Apr 22, 2007 | 12:10 PM
ejlarson's Avatar
Hi guys!
I have searched the Forums but can't find the exact info I am looking for. I have a 1999 4Runner SR5 V6. I am trying to replace the front Rotors due to some mild warpage. I can't seem to get them off, and am not sure how to do it. Are they the "fall off" kind, or are they like the 96s where I have to remove the whole hub?
Any ideas?
Thanks in advance!
btw, I am going to be selling it asap if anyone may be interested. I will post a message about that later.
Old Apr 22, 2007 | 12:14 PM
manofsteele2003's Avatar
Yeah they are the pop off type. Once you removed the caliper the rotor should come off. If it doesn't come right off, persuade it a little bit with a hammer and that should knock the rust loose that's probably holding it.
Old Apr 22, 2007 | 12:20 PM
ejlarson's Avatar
Thanks for the quick response man!!
I guess I should have stated that I did remove the Calipers already!
I have been persuading them with a rubber mallet quite a bit. I also squirted them a lot with WD-40 behind them where they mount. Still no joy.
I wanted to check with you fellas to make sure they come off before I REALLY start to put the muscle down on them and end up breaking something ya know?
Old Apr 22, 2007 | 12:50 PM
Shirleyda4runner's Avatar
I had to use PB blaster and a sledge hammer to get mine off...
Old Apr 22, 2007 | 01:29 PM
DeathCougar's Avatar
96's were also fall off style. 95 4Runners were bolted to the hub assembly.
voiddweller
19
May 2, 2016 09:10 PM
miceal383
Jun 29, 2015 12:27 AM
Iceman4193
Jun 28, 2015 10:30 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
