TT lift help please, I even searched!
Old May 2, 2007 | 07:08 PM
Kintore's Avatar
TT lift help please, I even searched! And can the 2.7 handle it?
hey guys, this site is SO addicting. Its nuts lol, already painting my wheels black, bumpers, getting clear corners, 31's, true flow air system, and deckplate mod.
Now I want a lift, I was looking at the
2.5" 4Runner Lift Kit
$269.99
+ $25 S/H Included in kit:
2.5" Front Lift Spacers-- CNC Machined From T-6 6061 Aluminum
3" Rear Lift coil springs (2" lift rear coils also available-same price)
Install Directions
I have a few questions, Im a TOTAL newbie when it comes to this. And yes Ive read the FAQ too
When you add lift spacers, I know it makes your ride suffer. But is that all I have to do is place those spacers between the coil and mount?
And for the rear all I have to do is place the new springs? no new shocks or anything like that?
Will 31's work on a lift like that? or am I going to be farther around with running a 1' body lift?
EDIT-
Can the 2.7 motor handle the lift and 31's? Im going to add a borla exhaust, deckplate mod, true flow filter thats it.
Any suggestions or opinions please, thanks for all your help!
Old May 2, 2007 | 07:12 PM
MillerPKA's Avatar
31s will work with stock suspension man. you can run up to a 265/75 on stock suspension/16in wheels which gives you a tiny bit over 32". 2.5 inches of lift will allow you to clear 285/75s, which are 33s
Old May 2, 2007 | 07:22 PM
Kintore's Avatar
Ok thanks buddy, now my next question is. Can my 2.7 handle it? lol
Old May 2, 2007 | 07:31 PM
MillerPKA's Avatar
yeah you'll be fine. may be a little more sluggish off the line but the 2.7 is definitely capable of handling a 2.5
Old May 2, 2007 | 07:34 PM
Kintore's Avatar
Ok thanks, im only going to be running 31's so I might just take the 1inch body lift route or the 2.5 I cant decide!
Old May 2, 2007 | 07:44 PM
89silverpu's Avatar
Can it handle it............that would be a big 10-4
If a 22re (2.4L) can handle up to 32's without re gearing (33's are possible but it would be oober slow) then a 2.7 can handle 31's and a mild lift. I have a 22re running 31's and no lift and it's definately no racecar, but it does great for what it is. I can hold 80 on the freeway no problem.
If you are not going to run larger tires, I wouldn't waste money on body lift. It would just give you a higher center of gravity)
Oh and welcome to YT, and yes it is very addicting
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
