Help! OEM Fog Lamp Install
Old May 10, 2007 | 09:35 PM
Derekb's Avatar
I purchased an OEM Hella Fog Lamp kit from a member and bracket kit from Toyota. There we no instructions on mounting the brackets and I can't figure out where they go.
This is for a 1997 4 Runner Limited
Any help?
-Derek
Old May 10, 2007 | 09:51 PM
kevin444's Avatar
On the 96-98's the original location is the valence area right next to the front license plate area.
On the 99-02's is obviously the little holes next to the signal nights on the fat lip bumper.
Old May 10, 2007 | 10:36 PM
Derekb's Avatar
What I'm having trouble with is the brackets are about 10 inches long and are marked left and right. There are two mounting holes and another for the lamp itself.
Still doesn't make sense where the brackets go. I've seen the location of the lamps but don't know where these things mount.
Derek
Old May 11, 2007 | 12:40 AM
kevin444's Avatar
Maybe you can have a guy or some online user who owns one take some pics on how they are mounted?
Old May 14, 2007 | 12:10 PM
luxdlx's Avatar
Where did you get them and how much? I need a set too.
Old May 14, 2007 | 01:22 PM
2000t4r's Avatar
Take a picture on post it so we can take a look and try and help
Old May 14, 2007 | 09:03 PM
Derekb's Avatar
Got it figured out. The brackets mount to the support behind the license plate and an open bolt hole on the lower part of the chrome bumper. I purchased the kit for $55 from the dealer (more than the lights, wiring, relays and switch) but I wanted the factory look. You have to cut the bumper anyways so it ended up a waste of money. Easier/cheaper to fabricate some mounts.
Derek
Old May 15, 2007 | 06:40 AM
2000t4r's Avatar
Good luck and post some pictures when you get it all installed
Shoua
13
May 22, 2016 05:19 AM
mbomberz1
Aug 8, 2015 06:57 AM
Esibnitsud
Jul 30, 2015 08:21 PM
TDonkey
Jul 26, 2015 10:14 AM
horunner1x
Jul 10, 2015 06:33 AM
