Fan blades broke
Old Apr 22, 2007 | 12:21 PM
MellamoPOUND's Avatar
Fan blades broke
I went wheeling yesterday and somehow broke 2 of the blades off my radiator fan. (97 4runner) My friend said it may have happend because of the big mud pits I went into, but I'm confused on how that would break the fan? Is there a beefier fan I can put on there? Where should I get a new or used fan to replace my broken one? The whole truck is very shakey when in idle because of the fan and I'm not quite sure if I should be driving it while it is like this. The temperature seems to be ok though. Any help would be great!
Old Apr 22, 2007 | 01:30 PM
DeathCougar's Avatar
dont drive it until you replace that fan. if it comes apart, its taking parts with it.
Old Apr 22, 2007 | 01:38 PM
woolsocks's Avatar
I'd park it. The fan exploded in my old 91 and put a bunch of holes in the hood.
Old Apr 22, 2007 | 01:43 PM
Chief_Yota's Avatar
i had the same issue wit the broke fan but i got an electric fan actualy ,i think its juste the fact that u took a very serious bump offroad fast enough to move everything forward for a split second while the fan was working.
Old Apr 22, 2007 | 01:48 PM
Chief_Yota's Avatar
anyway thx to that flexalite rugged ish ,it still in pretty decent shape,and still pushing alot of air in!! i love my fan.. exept for the fact that i had some wire fires in the past ,but thats just my fault.
Old Apr 22, 2007 | 02:48 PM
Ok, I'll keep her parked. Thanks
Old Apr 22, 2007 | 03:02 PM
I found some replacement fan blades online but I'm unsure if I should just get the oem replacement or if I should get a Dorman high quality one. Anyone know if its any better?
Old Apr 22, 2007 | 03:14 PM
get OEM only. That aftermarket junk is cheap and will shatter must faster than factory. Their "high quality" is equal to toyotas lowest quality, catch what I mean? For a well known problem area, dont risk it. You dont want that fan exploding and taking out your radiatior, hoses, fuse block, etc etc. That stuff gets spendy quick.
Look at it this way: Save a little now, pay a lot more later OR Pay a little more now, save a LOT later
Old Apr 22, 2007 | 03:25 PM
Thanks...good thinkin
Old Apr 22, 2007 | 03:45 PM
I just went out and looked at the damage again, and I noticed that a section of the radiator has been gashed by the broken fan blade. The indent is about 2 inches long. Do I need a new radiator now also!?!?
Old Apr 22, 2007 | 03:48 PM
keithguts's Avatar
Well if it was me, if it isn't leaking, I leave it be for now.
Old Apr 22, 2007 | 04:17 PM
if its not leaking, its fine. but be sure to pressurize and check for leaks. often they wont leak until pressure (IE warmed up, or forced air pressure from a tester) is applied
Old Apr 22, 2007 | 04:23 PM
Elton's Avatar
i wanna see pics
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 4, 2015 11:30 AM
puddlepirate
Sep 29, 2015 08:02 PM
voiddweller
Sep 28, 2015 11:21 PM
mtrdrms
Sep 26, 2015 07:12 AM
