Changing coolant
Old May 5, 2007 | 04:24 PM
Changing coolant
I need to change coolant in 02 4 runner 2WD, I will use Toyota Red coolant, I mixed 50/50 with water . which is the correct way to change it ? Please give me some inputs.
Thanks.
Old May 6, 2007 | 07:13 AM
Mark in MD's Avatar
http://www.google.com/search?q=chang...e=utf8&oe=utf8
Old May 10, 2007 | 06:33 PM
Somebody out there ?
How do I avoid overheating ? someone out there ?
Old May 11, 2007 | 06:11 AM
4Runner4Christ's Avatar
Louis,
Please use the search function provided here before posting new. A search for "coolant" or "overheating" gives many threads that could help you.
Here's one:
https://www.yotatech.com/forums/f120/coolant-problems-104102/
There's also a Newbie Tech Section that will help you a lot:
BTW, this is posted in the wrong category for your year Yota... Good luck!!
Old May 11, 2007 | 06:51 AM
Stevo3's Avatar
Originally Posted by 4Runner4Christ
Louis,
Here's one:
https://www.yotatech.com/forums/showthread.php?t=104102
https://www.yotatech.com/forums/forumdisplay.php?f=120
Its posted in teh correct section, he did say 02 4runner
But yeah, the search will bring up many things that will help you out.
Old May 11, 2007 | 02:19 PM
My bad...didnt read the whole signature.
Old May 11, 2007 | 06:45 PM
Upper hose
Thanks for the links guys.
I also read somewhere that : If I squeeze the upper hose while running warm up with radiator cap off, It also help to get the air out of system, is this true?
Old May 11, 2007 | 07:52 PM
rimpainter.com's Avatar
Yeah, I squeeze the upper rad hose a few times to work out the bubbles. Buy some Prestone flush and follow the instructions on the back to do everything. By the way, you can use GM Dexcool - which Wal Mart carries - to do the change. They have the best price. Be sure to use distilled water too.
Old May 12, 2007 | 12:19 PM
Thanks all replies. The informations from your guys will help me alot on my next coolant change on 02 4runner. Have a great weekend.
the1998sr5
15
Jul 14, 2020 08:35 PM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
the1998sr5
Jul 16, 2015 06:20 AM
ryerye13
Jul 14, 2015 08:27 AM
