cruise control=sporadic
Old May 11, 2007 | 08:24 AM
hanksyota's Avatar
first off, i searched to no avail so here it is. i drove 615 miles from denver to kc last night. the cruise control was working like a dream and then about 400 miles into the trip, it would start shutting itself off randomly. cruisin along fine, then the light would shut off, and it would blink twice. after i turned it back on it would work fine again for a while, then shut off. any ideas?
Old May 11, 2007 | 08:52 AM
fullmann's Avatar
not sure if it applies to your application, but my 00 5-speed needs the clutch to be FULLY at the top of its throw for the cruise to work.
i've had to tap the bottom of the clutch with my left toe to make sure it was all the way up for the cruise to work.
Old May 11, 2007 | 06:58 PM
olsy1984's Avatar
same here...worth a look atleast!!
Old May 12, 2007 | 10:22 AM
hanksyota's Avatar
cool, i will try it.
Old May 14, 2007 | 05:32 AM
gregbreakseverything's Avatar
I dont know about your 4runners, but my cruise light will turn on when I turn on cruise with the on/off switch, and stay on untill I turn off the cruise with the on/off switch, or shut the ignition off. Meaning, if your cruise light is turning off, it most likely will not be a problem with your clutch,brake,and cancel switches. I am not certain where to trouble shoot from there, but I bet a multimeter is involved. Goodluck.
Old May 14, 2007 | 07:10 AM
hanksyota's Avatar
well, i dont think its clutch but it did happen again a couple times driving back yesterday. did it at about the same time about 400 miles in. still havent figured it out.any other ideas??
Old May 14, 2007 | 11:16 AM
DOT3's Avatar
Check you clutch pedal bracket and make sure it's not cracked or loose. If it is, your clutch switch would cause the cruise to disengage.
Old May 14, 2007 | 02:37 PM
SpeedyJ's Avatar
I just took my Runner for a spin and tried this out, worked like a charm! And I thought my cruise control was shot! Is there anyway to get the clutch to disengage fully by itself?
Old May 14, 2007 | 02:53 PM
hanksyota's Avatar
im leaving work soon, i will check the bracket. glad this post has helped someone....haha.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
