Ac Pump
Old May 9, 2007 | 09:37 AM
kawicowboy's Avatar
Ac Pump
Does anyone know if an ac pump from the earlier years like 93-95 will work on a 96ltd. My pump is pooched and I cant find anything for the 96s and up.
Old May 9, 2007 | 04:22 PM
breknraj's Avatar
The compressors will have a different pulley on the clutch. 90-95 used v-belts. The 3rd gens use a flat belt.
There would also be the issue of being sure that the older compressor had R-134. I believe that the change to R-134 occurred in the '94 model year.
Other than those issues, it should bolt up OK, or with only minimal modifications. If you just swap the hose plate from your existing set-up to the other compressor, it should be do-able.
Old May 10, 2007 | 01:22 PM
kawicowboy's Avatar
The reason that im thinking this way is because out here they seem to be more readily available. Has anyone tryed this befor, and what were the results.
Thanks
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
daddio
Aug 9, 2015 07:17 PM
TJWilly
Jul 31, 2015 02:05 PM
calderp
Jul 27, 2015 09:58 AM
Jonny246
Jul 24, 2015 12:37 PM
