- My New SE Hood!
- timing belt w/p etc. replacement??
- What does this sound like to you? 5vz-fe in 96 4Runner
- Help tailgate
- Transmission dipstick broke in half while checking level
- Coolant and Refrigerant - leaks and fixes??
- Got Rear-ended...now confused
- 5vz differences
- O2 Sensors and running lean
- Bad Vibrations?
- Rear Brakes 2002 4Runner
- Adventures in maintenance: 2000 4runner ltd
- 96 4 Runner Lift and Tire Question
- 2000 4Runner differential
- rear shock problem.
- Need help making a few decisions about lift....
- 5VZ-FE power bolt-ons??
- Stolen Catalytic, and now Error codes
- 2.7L need alot of help!!!!
- Stripped spark plug on 3.4
- Paint touch-up on grille
- '96 Taco transmission problem
- Need some wiring help. Sunroof & Rear Window T4R!
- Quick intake question.
- Walmart brand SuperTech?
- Tacoma to 4Runner seat swap ??
- Swapping gauge clusters.
- Baja Bumpers front bumper.
- Poor Engine Performance
- Help getting front struts back in the lower control arm
- Need opinion : AC service part and tools...
- Weird noise when revved!??? HELP
- Warn control Box and front grill not fitting
- ARB/Warn Solenoid Mount
- Post pics of high clearance 3rd gen rear bumper..
- Body lift question..
- cleaning spark plugs with wd40
- Wheel Wobble and Tire on Roof question
- '00 4Runner Tailgate window won't work
- cryoscience.com
- cheap drawers
- Treadwright tires......initial review
- DIY 3rd gen alignment questions
- Vanishing Coolant in my 3RZ
- 99 interior facelift (lighting)
- Quick blinker bulb question; in the middle of changing
- Higher Wattage Headlights vs headlight fuses & harness
- 99 4runner with wierd issue
- Sounds like ...... diagnosis
- fender flare extension needs reattachment '97
- sliders are on...next comes paint...
- problems with new clutch?
- 99 tacoma rear end
- Quick Release Sway Bars
- Installing 2.5" lift kit on taco???
- Help with bouncy/wobbly 96' Runner ride!
- Tailgate
- HELP! Cant pass inspection
- Tranny wont stay in gear
- 16'' to 15'' wheels
- Not starting after top end rebuild
- Steering rack bushings holding up?
- 2x3 toyota rims...
- Tacoma 4cyl - V6 rear axel swap?
- Replacing Clutch While Replacing Engine
- ECU location
- skid plate reinforcement
- Premium exhaust hanger?
- Has anybody with my same setup done the Tundra Brake Conversion?
- 1999 2.7 Taco fuel shuts off after 2k rpm
- O2 Below Threshold NEED HELP!
- 500 to 1200 - 1800 Idle Fluctuation
- Rear axle seal - scratched axle housing - fixes?
- Heated Power seats
- Same drum size between 15" and 16" wheels?
- How much oil does the manual transmission hold?
- winch + install question
- Good Replacement seats?
- Quick gauge bulb question for 99 taco
- a/c recharge mechanix procedure..standard?
- Tool to use to change 3rd brake light
- Lower/Upper Link bolts, torque specs?
- I put my lift on too!
- Gauge/cluster lighting...insight
- ome setup Q's
- 2003 4x4 Db-cab, shocks?
- clutch on its way out?
- Monroe shocks work with 3" ome coils?
- 18" Magnaflow installed today; have questions
- What size bushings for 4Runner sway bar end links.
- Blower motor squealing
- eLocker install
- 1998 4runner problem!
- American Racing Outlaw II Wheels on a 3rd Gen
- 95-96 front end
- Valves question
- Alarm remote?
- 2001 Front Bumper ?'s
- Replacing shocks
- Slack in drivetrain but only in 4WD
- True Dual Exhaust
- VSC/TRAC beep disable
- AC noises
- My 4Runner today wouldn't stay running after firing it up, just dies...
- i am running 34 inch tires with only a 1.5 inch body lift
- Stock amp from 97 with aftermarket H/U question
- cruise control notta workin
- Brake light fuse keeps burning
- Okies off-road improvement thread
- Lifted my 4runner finally, PICS
- new lift
- 00-06 Tundra coils lift 96 4Runner
- Found some FJ80 springs - but have ???
- Rough Running '97 4Runner
- New Tires
- How difficult is it to replace the Centre Bearing?
- 00 Limited - "jerking/catching" feeling when first moving forward
- 96 Limited 4WD Help!!!!
- Front Mud Flaps for 02 4runner
- Baffle Broken Inside Cat Converter...How to Fix?
- Weird gas guage issue...
- stolen cat
- weight of a 1997 4 runner
- ss 1.2 lift q's
- Successfully replaced OEM antenna mast?
- A few questions
- In-glass antenna
- Is this symptom a broken Trans Mount??
- lifted 4runner in hendersonville
- Trac off/ Vsc Trac lights came on, need help!
- powdercoating aluminum 3rd gen wheels
- 38's on a 98
- Sending unit for gas gauge
- 01 tacoma transfer case
- How do I tell if my '00 Tacoma is Cali or not?
- Mass complaints of Engine knock on 3rzfe Motors????
- Just checking in, nothing big for now
- 99 Taco, Bob and Chop.
- New member 2002 4runner quick ques...
- Replacing a CV Axle on the trail
- on road fog lights on ARB bumper
- Overheating Woes
- wiring rear oxygen sensor ...please help!
- What other seats might fit, in a 02 4Runner?
- bought some new wheels
- Tundra Brakes and 4454 transmisson cooler - Ultimate torture test
- 2003 Highways Speed and engine damage??
- 1997 2.7 Liter 2wd - blown head?
- 3vz-fe performance
- 2003 Tacoma occassionally hard to start
- Gas latch???
- grinding/clunking when fully stuffed in 2wd
- 3.4 + 4.10's + 35's = slow
- Rotating Front Leather Seats
- Panhard bar / track bar question
- Power Steering Flush
- blown headgasket
- 3.4L slightly rough from ~2200-3000 rpms
- HELP! Terrible Chasis/Suspension Sqweak!!
- PO78 Shift Sel Circuit B Electrical?
- Castrol Edge is WAY better than Mobil 1.
- Installed my Ivan Stewart rims
- 3rd gen front alignment question
- 4wd not working right....HELP!
- Lift Help...
- Hooking up trailer lights???
- '99 coil spring question...Newbie on board!
- Its about that time
- supra steering wheel...
- Looking for 99 Tacoma rear bumper
- How often do you use ECT PWR??
- Aftermarket fuel gauge
- I need some help
- Finally!.. Pics of my 4runner
- E-locker Wiring Pop Quiz
- Can I remove CA emissions?
- Anyone retrofit an armrest??
- 4runner smash captured on traffic cam
- Amsoil or Toyota Driveline Fluids?
- Just finished installing TRD headers on my 3.4 4runner...
- 98 4runner 160K miles
- Short vid and pic from Straddleline ORV
- Lift installed (pics) + bumpstop question
- New member...radio/clock not working
- 3.4L Fuel Filter Interval????
- resurfacing a flywheel how important?????
- DIY'er 90k service?
- 96 Tacoma sits for 4 years...
- CatBack Vs. Free Flowing Muffler
- Looking at new leather
- Deckplate mod does nothing
- Block heater questions...and good write-up?
- Tie Rod Thread size?
- 2000 tacoma 2.7 l CEL P0325
- Best year 3rz and where to get?
- HELP me identify this lift!!
- New Gadget
- A/C Issues
- What did you do with your old rotors
- Strange sound when I remove Oil cap???
- Performance mods???
- replacing fluids, need advice
- 98 Tacoma Won't Start
- 'I love my 3rd Gen' Appreciation Thread
- 3.4L V6 87 Octane gas Problems
- Bad Deal... 3.4L gives up
- Anyone have an 2.7 intake for sale?
- Help finalizing my lift decision...please help!!!!!
- 99 taco radio
- K&N Cai Installed!
- OME spring install question/problem ??
- '99 coils and rear spacers??
- SNORKEL 2001 4runner?
- Ok, truck been running great for a year and then all of the sudden won't drive?
- Supercharger Help for a Friend
- Flush Tranny or not?
- Getting an e-locker
- Lower Ball Joints questions
- Rear Differential Fill Quantity
- 00 4wd question
- Braking torques front axle
- Just Finished Cleaning My Interior, complete strip...with pics
- Saggy Butt Syndrome. New Shocks?
- 4runner looked so good, just had to snap a quick pic!
- Skid Plate Fitting
- Buzzing Evap Canister - Part to fix discontinued
- Axle and Spindle replacement
- P0171 after valve cover gasket change
- 3.4L warm start stall
- Best lift kit for 2WD 99 4runner
- racerunner rebuild -- circlip help!
- 2ND Gen TJM17 on a 3rd Gen 4Runner
- Replacing ball joints and axles
- I need a valve adjustment HOUSTON Tx
- Spark plug question
- Suggestion for 97 4Runner suspension upgrade
- Difference between the SR5 and the Limited?
- My new sleeping platform, plus some surf/camp pics from 7/4 wknd.
- Any ABS (and/or '01-02 VSC/TRAC) experts?
- towing with overdrive?
- Another gas mileage thread...done just about everything and still ~15-17mpg
- and the mods begin.. again...powder coated 17'" fj cruisers on 02 sport.
- Trailer wiring plug
- Mobile One 5W-40 oil change results
- 3.4 L problems
- Rudy's Midnight Mods
- Metallic squeak when I apply light throttle and when I let off the gas
- ?? about ARB and Shrockworks front bumper
- What could this popping noise when turning be...?? i already replaced both cv axles
- TRD 3.4 superchargers smog legal in cali?
