3.4 L problems
Old Jul 6, 2009 | 05:04 AM
bain's Avatar
3.4 L problems
OK..The truck idles really really smooth.. But during acceleration it surges or hesitates and doesn't seem to want to wind out and it doesn't have the power it should. I have new plugs and fuel filter and it didnt fix it. Could it be the coil packs? Thanks
Old Jul 6, 2009 | 05:24 AM
Elton's Avatar
what plugs did u go with did you also replace the wires ? how about cleaning the maf sensor air filter good too ?
Old Jul 6, 2009 | 07:34 AM
BajaRunner's Avatar
Check/Clean MAF (Air flow sensor which is directly behind air filter) with electro-contact cleaner, and clean your throttle body with throttle body or carb cleaner.
Any vacuum lines disconnected or leaking?
Check all the simple stuff first!
Old Jul 6, 2009 | 07:37 AM
bain's Avatar
I pulled my packs and one plug looks brand new and the other looks used...must be the pack
Old Jul 6, 2009 | 07:43 AM
hross14's Avatar
As always we need more info. Miles, auto or manual, year of truck, mods----details man--details.
But here is my initial diagnoses--i will assume it has over a 100K
**Replace both O2's or in later models AFR and O2
**Replace the TPS switch--its cheap, just do it
**Clean the MAF, Throttle body and IAC
**Take out the injectors and have them sent out to be tested and cleaned
**check resistance values on your coils
**Plugs and wires (Hint: the only reason Toyota used dual electrode plugs was because of the wasted spark system--they fire twice as often)
**Do a leak down or compression check to get a general idea of what condition the engine is in. You can get this all done in a day less the return time for the injectors.
LAST BUT NOT LEAST--SEARCH--there is tons of people with this same issue and our suggestions
Old Jul 6, 2009 | 10:20 AM
bain's Avatar
First off..thanks for the help..Ive searched for a week and didnt learn anything helpful so I thought Id try a new topic with new input.. Its a 98 3.4 4X4 5 speed 103,000 . Its got new O2 sensors,new plugs and now new wires and coil packs (all Toyota). The MAF has been cleaned. I just replaced the coil packs,plugs and wires and it got worse. If you set and rev it , its smooth as hell but when you take of it feels like a light case of running out of gas. You can floor it in 3rd gear and it will stay the same speed with the hesitation.. Would a bad injector across from the plug that always looks new cause it not to fire?
Old Jul 6, 2009 | 10:24 AM
bain's Avatar
and does a TPS have to b calibrated in any way or do you just put it on?
Old Jul 6, 2009 | 11:05 AM
hross14's Avatar
I suggest the injectors because every set i send out at about the same miles comes back with a poor pattern and less CC's flowed.
The TPS just bolts on with no calibration. Also, if it got worse maybe rechecking the firing order might help--they might have gotten mixed up.
You might also want to sweep the Knock Sensors--just saying
check OHMs on the fuel pump also--but i put that one low on the list....
Old Jul 6, 2009 | 11:20 AM
904_runner's Avatar
it needs to be adjusted properly..
Look up specs in a toyota manual..
You need to use an ohm meter to get it proper.
Google "toyota FSM" and a result will be from ttora and they have factory toyota service manuals uploaded that you can use...
Old Jul 6, 2009 | 11:40 AM
Yota Runner's Avatar
Check the boots on the coil packs for cracks. It doesn't take much of a split to make it run crappy. Roll the ends between your fingers while squeezing. There should be no splits, cracks or anything.
Old Jul 6, 2009 | 12:37 PM
bain's Avatar
coil packs and wires are brand new.. cleaned MAF again and checked TPS (it was good). I checked the new plug just now and it still looks new..could it be a dead cylinder? I'm confused because it runs smooth until i accelerate up a hill or get on it....I'm getting a compression test done Wednesday..
Old Jul 6, 2009 | 12:40 PM
904_runner's Avatar
Yes do a compression test to see whats going on internally. If everything turns out good there and the TPS and all the other sensors are good, the only thing i could possibly think of is maybe a clogged cat.
So your saying when your pushing it it just falls on its face? NO power??
Old Jul 6, 2009 | 12:55 PM
bain's Avatar
pretty much. if i have to give it gas to get up a hill it has no power nd you can fill it missing
Old Jul 6, 2009 | 01:05 PM
904_runner's Avatar
if you can feel it missing, i would seriously check your plugs/wires/coil packs
there is a possibility it may be bad, even though its new. Are you sure all the wires are connected all the way?
Old Jul 6, 2009 | 01:15 PM
bain's Avatar
yea..triple checked.. I just got to figure why #5 isn't getting any fire...gotta be a bad injector or a dead cylinder...that's all i can think of..guess ill find out Wednesday..
Old Jul 6, 2009 | 04:16 PM
vital22re's Avatar
totally a bro
Do a compression check on 1,3,5 that will help rule out a lost cylinder.
Old Jul 6, 2009 | 04:36 PM
bain's Avatar
im pretty sure #5 is gone...thats the luck ive been having with this truck...
Old Jul 6, 2009 | 05:09 PM
FJHammerHead's Avatar
After I took out my MAf and cleaned it, then reinstalled. I had the same problem because I didn't have the MAF plugged in all the way. Worth another look.
Old Jul 6, 2009 | 05:20 PM
bain's Avatar
ill double check that tomorrow..thanks... would that cause the #5 plug to look unused and the rest look normal?
Old Jul 7, 2009 | 06:47 AM
hross14's Avatar
Unless your 3.4 is different from the ones i have worked on--they dont need to be adjusted. There arent any provisions for them to be adjusted. Only the 4 cyl
The compression and or leak--down (this is the one i prefer--more consistent) will let you know what is happening as far as valve leaks and etc. But if all sensors check out and etc...you are just going to have to keep digging. I am assuming you are mechanically inclined and checked all the small stuffs. Take a look at the injectors.....
Did you pressure check your Fuel pump/system?
