Help getting front struts back in the lower control arm
Old Aug 2, 2009 | 12:07 PM
PeteV's Avatar
Put new struts on my '02 4Runner, but can't get the shock to compress enough to get it into the control arm. I know I've done this before, but the gap never seemed so big (need about an inch). Any ideas/tricks to this?
Old Aug 2, 2009 | 12:11 PM
scuba's Avatar
Place you stock bottle jack on the fenderwell and crank the UCA downwards..
Old Aug 2, 2009 | 12:14 PM
PeteV's Avatar
Tried this, but it keeps slipping of the UCA. I'll try again I guess....
Old Aug 2, 2009 | 12:25 PM
dannomite's Avatar
I used the jack trick and it worked for me. I did have to find the sweet spot so the jack would sit still for me though.
Old Aug 2, 2009 | 12:40 PM
Beefed Taco's Avatar
Try this, it's works for me....use a ratchet strap that's attached to the arm and to the other side of the truck (the other arm usually) and pull the arm all the way down, then another strap going around the bottom of the coilover (strut) to keep it from wanting to pop outward, and you should be able to use this strap to pull the bottom close enough to get something like a fat screwdriver into the hole and help get it aligned enough to put the bolt through.
Old Aug 2, 2009 | 02:18 PM
bain's Avatar
i used a big ass bar and stuck it through the control arm up against the frame and then i sat on the bar to pull it down more....worked for me... or you can loosen the lower ball joint.
Old Aug 2, 2009 | 04:05 PM
PeteV's Avatar
The jack trick worked, I just needed to put the top of the jack on the wheelwell, and the bottom of the jack on the upper control arm. I was trying to do the opposite, 'cause I thought the top would push through the wheelwell, but it didn't.
Old Aug 3, 2009 | 01:10 PM
narfy's Avatar
i disconnected my front sway bar end link from the sway bar... then it slid right in...
Gravel Maker
RuffStuff
Jul 6, 2015 07:43 PM
Niameyrider
Jun 25, 2015 05:50 AM
ranma21
Jun 22, 2015 11:55 AM
2wdtundra
Jun 17, 2015 01:41 AM
be_deviler
Jul 1, 2002 05:27 PM
