Bad Vibrations?
Old Aug 5, 2009 | 09:01 AM
Raddogz's Avatar
Bad Vibrations?
About two years ago I replaced my muffler and exhaust pipe as the pipe had broke off from the muffler. Almost a year later it does again, and now almost a year to date it has happened again in the same spot.
Any ideas as to what could cause something like this?
and what the hell should I do
Old Aug 5, 2009 | 09:09 AM
scuba's Avatar
What kind of truck ? what year what engine ? Are all the exhaust hanger still there..?
EDIT: gotta provide more info if you want some help dude.
Old Aug 5, 2009 | 09:25 AM
desertcamper67's Avatar
Is this a low spot in your exhaust? If so water could be pooling there and promoting the rust. I've seen a pinhole left on purpose to eliminate this. A drain hole if you will..
Old Aug 5, 2009 | 09:30 AM
scuba's Avatar
Well, a suggestion is your exhaust hangers could be screwed.
This is on my 99 Taco 3RZ, Its a bracket that hold the downpipe to the transmission to keep vibrations down.
Make sure that is there..
Old Aug 5, 2009 | 10:29 AM
Raddogz's Avatar
info
2000 4Runner 4WD Limited
3.4L V6
One would like to think the dealer would have checked the hangers before re-installing?
Old Aug 5, 2009 | 10:34 AM
scuba's Avatar
Idk, One could go out and check right now to make sure..
Old Aug 5, 2009 | 10:41 AM
malteserunner's Avatar
You could install a flex pipe to reduce some of the stress on the muffler. Any muffler shop should be able to help you out. Good luck.
Blamalam
Aug 16, 2015 12:29 PM
tinigunner11
Aug 14, 2015 01:19 PM
lectric80
Aug 11, 2015 12:02 AM
