99 tacoma rear end
Old Jul 30, 2009 | 05:26 AM
TillysToy's Avatar
Post 99 tacoma rear end
ok i put 3inch blocks in the rear to even out the truch bc the guy i bout it from didnt and it has a lift but he never put the blocks under the back so it was 3inches lower than the front. But now i got a vibration when I start off and when I let my foot off the gas going down the road. Do I need to do something and lower the nuckle bolted to the cab? if so whats the best thing?
Old Jul 30, 2009 | 08:23 AM
scuba's Avatar
The blocks might just be your first problem...
Old Aug 2, 2009 | 02:28 PM
bain's Avatar
sounds like bad driveline angle
Old Aug 2, 2009 | 03:49 PM
89silverpu's Avatar
x2 or a bad U joint
blocks aren't as bad as people make them out to be. When you start running the huge 6'' lift blocks is when the trouble starts. A 3'' block is fine you may just have a tiny bit more axle wrap, but the stock shock set up should minimize that to begin with with some good shocks. Speaking of shocks, did you get longer shocks?
smthwsn357
May 1, 2024 07:28 AM
Daneums
Aug 20, 2015 05:36 AM
TokyoD23
Jul 12, 2015 06:01 AM
akaphilly
Jul 9, 2015 02:18 PM
toyoda8488
Jul 5, 2015 10:18 PM
