PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Knocking Sound
  2. Colorado Blizzard & Mashed Bumper
  3. My supercharger is no longer 'Super'
  4. 1997 4 cyl needs more pony power
  5. Tacoma/4Runner guys...need some measurements
  6. remove 97 4Runner plastic instrument panel
  7. 4runner tires on my Tacoma
  8. Rear Window Remote
  9. Gabriel Hi-Jackers ordered!
  10. 3rd Gen Spotted - Calgary (pic)
  11. Silencer Mod alternative?
  12. Locker woes
  13. Horrible gas mileage.....
  14. Where to get a panel painted
  15. Rear compartment strap removal
  16. Biggest tires for PP lift
  17. '01 SR5 Flare Removal
  18. Auto Transmission Click Shifting into P or R
  19. Which Lift Kit Do I Want?
  20. Cupholder Modification...
  21. Sonoran Steel System #3
  22. fog light help and front light help
  23. '01 tacoma keyless remote
  24. 95 Taco fuel injector, fuel trim questions
  25. 99 4runner -crankshaft pulley bolt - Reuse it? - Loctite it?
  26. Lug nut lock key
  27. 99 4runner - Transmission problem?
  28. Ingnition switch wire question
  29. Need some suspension help!
  30. 2.7 Tacomas?
  31. Rear diff shot at 130K?
  32. 5VZE V6 valve adjustment
  33. Shocks for my little red truck
  34. ABS Noise
  35. transfer case breather
  36. Strange Oil Leak
  37. Before I make final suspension descision? Please help!
  38. hood pin wire?
  39. Wider wheels for '96 4Runner
  40. Slow drain on battery...
  41. More Horsepower!!
  42. 2000 Taco check engine lght and dying?
  43. RE: URD fuel upgrade for TRD supercharger
  44. pics of my satoshi
  45. Roof Console in '98
  46. 1999 4runner 4WD problem
  47. Need help fast! Re: gears & locker scenarios & prices
  48. windshield wiper fluid reservoir
  49. Since I just ordered four 33x9.5s....
  50. Hard start!!
  51. Gearing suggestions
  52. Electric Cooling Fan? Verdict-Is it worth it?
  53. I need a detailed schematic of the combination meter!
  54. Tru Trac Complete Third
  55. Rubbing noise from front end
  56. Transfer case and color of oil
  57. substance all over rear axle
  58. 3rd generation starter
  59. Dual exhaust/muffler ???'s
  60. Clutch--Time for Replacement
  61. Swapping 96-99 Center diff to 4th Gen Torsen Center Diff
  62. Brake pedal goes all the way to the floor
  63. New Meats, Finally
  64. 96-98 grill question
  65. Bad luck Christmas Eve
  66. Lift question
  67. Missing top portion of sway bar end link!!
  68. Best 99 tacoma coilovers?
  69. 5speed double cab?
  70. Bad rear end cluck
  71. 2003 Tacoma Check Engine Light
  72. Toytec OME3-RUN lift on 2002 4Runner Sport
  73. 4whl low
  74. Is this a good deal???
  75. Tacoma engine hardware size
  76. Driveshaft pushing into gas tank...
  77. inconspicuous switch for non smokers
  78. Repacking front wheel bearings on a '98 Taco: How difficult?
  79. How many grease nipples on rear drive shaft on 4x4 4runners?
  80. Open Up Your Hood Scoop?
  81. Quick Rear Suspension mod for 4runners
  82. 1" body lift on 2001 4runner. Front bumper problems.
  83. Hayden electric fan
  84. Roll Bar and custom tire mount
  85. Just got my runner smogged
  86. Encouragement for DIY lift/locker install!
  87. Need help replacing my Radiator.
  88. 97' Gas Gauge Issues...
  89. 99 4runner losing oil
  90. 140k 98 4Runner opinions?
  91. where can i get taillight guards for 3gen 4runner
  92. 99 Runner -- Can the front seats be switched?
  93. Axles?
  94. 96 4Runner door ajar wire (door trigger)
  95. where to get a westin bar in ontario?
  96. TACOMA dilema
  97. Bumper Replacement
  98. 1997 4Runner / brake and steering vibration
  99. Odd noise from front coil spring??
  100. My new hitch (with pix)
  101. 4.10 in front and 4.30 in rear?
  102. Transmission not shifting
  103. Flange type oxygen sensor
  104. rear brake bulb replacement
  105. interchangeable gears?
  106. Whirring sound after transfer case oil change?
  107. Tundra Skid Plate on 99 4Runner (pic)
  108. Im guessing this is a bad bearing?
  109. Tie Rod Flip On Lifted Tacomas And 4runners
  110. Attention all 2WD 4Runners with Sonoran Steel Lift.
  111. where is my PCV hose on my 96 ??
  112. Quick E-locker Question
  113. Time for a new clutch.
  114. 95-00 AWD transmission?
  115. Headers
  116. what wheels?
  117. P0304 code - misfire in cylinder #4
  118. revtek + TJM of ARB front bumper
  119. Mattress/Boxspring on surco rack?!
  120. Supercharger Grinding Noise
  121. Excessive Oil Pressure
  122. Anyone running 285s with 2.7L 3RZ-FE?
  123. Oil leak btw Trans and Case
  124. Rear Differential Breather
  125. Front right suspension squeaks
  126. Gear Oil GL-5
  127. Onboard Air-Compressor Mount
  128. Larger Oil Filter - 50% more media...
  129. Rear Axle leak at Pumpkin!
  130. Rusty Rear o2 Sensor...
  131. Transmission Fluid Everywhere
  132. Re-gear or winch first?
  133. out of the shop..!
  134. Replacing front shocks - article?
  135. weird 3.4 engine rattle noise
  136. What's the purpose of rear spoiler
  137. transmission help needed.
  138. 1999 4runner Radio Power problem
  139. Tranny problem... Need help diagnosing cause
  140. Bullbars, safari bar, etc.
  141. Transmission Problems
  142. 4Runner won't start
  143. 4Runner Transmission Grinding and Whining
  144. BR-3 has a new version 4.0 available for their OBDII scan Tool
  145. $500 good deal on RR Diff lock?
  146. Opinions?: Taco SkidPlates...Skid Row vs. Bud Built
  147. What tires for 3.91 gears?
  148. Is this gap supposed to be here?
  149. No more 4Runner for me.... :-(
  150. Check engine light
  151. Clunk or slosh from Front Right?
  152. Caster adjustment after Tundra lift
  153. Check your Plugs!!!
  154. new bumper
  155. 99 front SR5 seats vs. 01 front bucket seats
  156. Is $232 a good deal for a hood scoop hood?
  157. 3.4 engine redline
  158. 3rd Gen Drawer system
  159. damn sqeek....why where???
  160. 98 3.4L 250K Maintenance Recommendations
  161. transmission issues
  162. Is new gearing needed?
  163. 4Runner capacities and Amsoil product numbers.
  164. My 02 Sport Edition
  165. Power steering rebuild
  166. changed driving style
  167. 96 4Runner Sway Bar link and bushings
  168. Shock Install - Major Problem and a Question
  169. planning ahead - need swiss army knife suspension
  170. loosing gas..... i think
  171. Jingling
  172. rough ride with Tundra/OME lift
  173. 3.4 Custom Alki Injection Install
  174. woes of front diff removal...
  175. backspacing?
  176. Anyone's CLOCK broken?
  177. Street Pics of Sonoran Steel System 1
  178. TJM 15 + M8000 Install/Question Thread
  179. starting problems
  180. Could not find good starter removal pic so posted one..
  181. Programming Key Fob
  182. Just introducing myself. (pics)
  183. 1996 4Runner: U joints or trany noise??
  184. Creaking / groaning noise from front end *solved*
  185. another axle seal question
  186. Oh Yeah! Got me a 4Runner.
  187. Fog Light - internal cleaning Micro DE
  188. Need help with automatic locks
  189. Axle seals
  190. Wierd noise when stress on the rear axle...
  191. E-Brake loose
  192. Slicks Windshield tinted plus neliconcept's RIDE
  193. Rt. Front Brake Locking up
  194. 285/75/16 BFG AT on Stock Sport Wheel
  195. Auto Trans. Question
  196. Tacoma reg. cab reg bed
  197. arghh 295's and endless rubbing...
  198. 2.7 tapping on start up
  199. Exhaust
  200. Brake light and Engine trouble!!
  201. Soft brakes after axle repair
  202. Hit 200 000 kms on my 99
  203. Ticking Pinging Knocking Compression
  204. Clutch
  205. 99 4runner trans oil
  206. Rear Inner Axle Seal Part number
  207. Dash illumination
  208. RR DIFF LOCK button problems
  209. starting problem not your usuall contacts problem
  210. Green wire with red stripe? Still dinging!
  211. HELP cd player... taillights dont work
  212. Transmission and transfer case rebuild
  213. exaust diameter?
  214. Shocks and struts
  215. Used 3.4 Supercharger that needs parts
  216. Best looking 3rd Gen Runner
  217. how do, first post, and help a brotha out...idle problems
  218. Hesitation Diagnosis: No Codes
  219. (HELP)2003 with TRD supercharger making noise
  220. HELP, will Taco rack and pionion fit 4Runner?
  221. '98 Taco Brake Booster Clearance Issues
  222. What is "flex plate" problem
  223. 1997 4runner Recall
  224. Cost effective brakes?
  225. 4wheel drive not engaging
  226. Will 275/70/16 fit?
  227. 98 5VZ front brake problem
  228. Rear Axle Rubbing noise = damaged axle?
  229. Quality of aftermarket tie-rods?
  230. OME question
  231. I'm looking at a 1998 TACOMA-any notorious problems?
  232. Rear Axle Bearing Install Check
  233. 96 4Runner 4x4 Issues
  234. Newbie needs an educatione here!!! 4wd broke!
  235. oil sending unit metric adapter
  236. Would you? Brakes for $190
  237. Transmission difference between '97 & '01?
  238. Help w/ CV Boots after TRD/LC lift
  239. 3.4 head gasket write up?
  240. Whip Antenna
  241. Radiator flushing
  242. Engine speeds up when heat is on?
  243. airbag squib
  244. New muffler
  245. 97 4runner engine, 4wd, steering, ect. problems
  246. 99 SR5 Question For Electric Gurus
  247. J.C. Whitney replacement leaf springs?
  248. Addco Sway Bar: Front only or F&R?
  249. Can stock suspension items from an FJ Cruiser be installed on a 3d Gen 4R?
  250. Broken Wheel Stud
