Whip Antenna
Old Dec 5, 2006 | 09:39 AM
Ehinfinity's Avatar
Whip Antenna
Just to make sure im not crazy, someone back be up. My dad is getting me the taco whip antenna for christmas, when he went to get it the dealership they told him he only needed the antenna and not the non-motorized unit. I did my search and read that everyone had used both.
Someone please confirm my findings that I do need both parts.
Eric
Old Dec 5, 2006 | 10:14 AM
Stump1883's Avatar
I could use some input on this subject as well, my motor recently gave out. BTT, hope someone chimes in soon.
Old Dec 5, 2006 | 10:25 AM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I've also been looking into doing this, not sure if my antennae motor ever worked while i've had my runner
Old Dec 5, 2006 | 10:31 AM
Erich_870's Avatar
Are you doing the "Taco Whip Mod" where you replace your current motorized antenna with the solid taco whip?
If this is the case then you DO need the taco stationary base as well. It will NOT work if you keep the motorized base.
Erich
Old Dec 5, 2006 | 12:05 PM
JC_ez's Avatar
I second the above. I did the whip mod and I needed both parts as well. I don't know if this has been mentioned already, but the wire harness that goes to the motorized unit will not be needed after you do the whip mod. So what I did was pull the wire through the fender into the hood aread (near the cruise control), taped the connector end really well, and tied it to the main wiring harness under the hood nearby. Have fun!
Old Dec 5, 2006 | 12:12 PM
garrett1478's Avatar
http://www.4runners.org/articles/whip/index.html
Old Dec 5, 2006 | 01:00 PM
TX-BLKRUNNER's Avatar
i have done this mod also, I can get the whole unit shipped for $60
Old Dec 5, 2006 | 01:45 PM
dbikeman's Avatar
You can buy the non-motorized unit for a 4runner and it comes with the whip part... I have the parts in my garage right now.
Old Dec 5, 2006 | 02:42 PM
seanz0rz's Avatar
Guest
yea i thought the base model 4runners came with out a power antenna.
so far my motorized hasnt failed me yet. about once every 6 months i give it a nice coat of grease, run it up and down, then wipe off the excess.
Old Dec 5, 2006 | 03:06 PM
waskillywabbit's Avatar
I've done this mod and you need the whole non power antenna assembly.
Old Mar 28, 2007 | 07:37 PM
johnw999's Avatar
I did the whip antenna mod today for my 2000 4runner. It was tedious, and it took me a little over 2 hours to do. The most difficult part was pulling back the black trim from the wheel well. I suggest this fix for anyone who has a power antenna problem. I fixed the power antenna once after 4 years of use. While I'm upgrading my sound system, I decided to do this perminant fix before it broke again.
Old Mar 28, 2007 | 07:51 PM
jwbehm's Avatar
Just to further clarify, you WILL need to non motorized unit. I did this a while ago, the only really pain in the arse part is getting the little plastic clips out wihtout breaking them. I ended up drilling mine out and getting new ones from the dealership.
Old Mar 29, 2007 | 12:33 AM
Jdizzydub's Avatar
Pretty sweet mod to do, but you'll need both pieces to complete it--you can access the antenna motor thru the fender on the ps. I just took mine out filled the hole, primed, and painted it and just went with an interior mounted antenna!
Old Mar 29, 2007 | 02:33 AM
X2and4X's Avatar
I was thinking about doing this until, I got my current alpine HU which only puts up the antenna for the radio. CD and Ipod the antenna goes back down and stays that way. I love it.
Old Mar 29, 2007 | 09:29 AM
johnw999's Avatar
Me too - I had to remove the plastic clips with the dremel. I replaced the clips with some plastic screws that I bought from Lowe's. The clips were designed for dry wall attachments, but they seem to work for this application. Just in case they don't, do you still have the part number for the toyota replacement clips? How much were they?
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
shisha1999
Sep 20, 2015 11:35 AM
Ilovemountains
Sep 15, 2015 04:17 AM
msged2007
Aug 22, 2015 07:46 PM
