hood pin wire?
Old Dec 29, 2006 | 07:43 AM
goohead's Avatar
hood pin wire?
hey im trying to program a remote start system and it is asking me to open the hood, then ground a gray hood pin wire if no hood pin is installed, anyone know where i can find this wire??
Old Dec 29, 2006 | 08:00 AM
ADH8796's Avatar
You will probably need to take your own peace of wire and ground it yourself I have the hood pin my runner but I never really had a clue what it was for until now lol. Good luck.
Old Dec 29, 2006 | 08:48 AM
MTL_4runner's Avatar
Is this a factory installed alarm or aftermarket?
Might help to know what alarm we're talking about here.
I installed an aftermarket and had to put one in (including running the gray wire to the hood switch pin).
Old Dec 29, 2006 | 11:12 AM
chad99's Avatar
sounds like the install manual is telling you to ground the gray wire from the brain....although it might be more of a pain to install a hood pin you really should just as a safety, I did so on my gf's car when i installed her remote start... if you do make sure to put some kind of epoxy on it or some thing to prevent rust or corrosion.
Old Dec 30, 2006 | 01:06 PM
goohead's Avatar
yeah its a aftermarket crimestopper rs900 vii wierd how i dont see a stock one on the car i went ahead and ordered one from the manufacture and will install it
Old Dec 30, 2006 | 01:14 PM
It doesn't come stock on the truck, I had to install one too as I mentioned (it came with the alarm).
Old Dec 30, 2006 | 05:01 PM
profuse007's Avatar
what unit are you using?
most of the units ive seen and installed do not required hood switch. If hood switch is grounded, RS will not work.
Old Jan 5, 2007 | 09:00 AM
rugerm44's Avatar
Thats so it cant be started if you are having it serviced.Not much fun changing belts and hoses while the engine starts by itself.Not to mention while there is no oil in the engine.The alarm remote start can be triggered by unwanted means.Its also good to have a switch to stop it from starting in an enclosed garage attached to your house.
raptor510
Feb 17, 2017 07:11 AM
keithporter83
Jul 18, 2015 12:37 PM
msane99
Jul 17, 2015 10:13 AM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
