2003 Tacoma Check Engine Light
Old Dec 24, 2006 | 07:47 AM
Back40Rebel's Avatar
Hi all,
Was on my Xmas trip back home & my check engine light started to blink. Pulled off @ the next rest area. Left it running & popped the hood & @ some point the light went off.
Kept going & 30- 45 min later the light started again.. pulled off @ next rest area, put it in park & within a few min it went away. Repeated that again, but this time the light stayed on.
During this whole time the truck runs fine, highway speeds without issue, no bucking, no hesitation.
Had the codes pulled to see what is going on here they are...
P0300
Random/Multiple
Cylinder
Misfire Detected
PO302
Cylinder2
Misfire Detected
PO305
Cylinder 5
Misfire Detected
Question: Is it safe to drive back home to fix or should I have it fixed before I go back...
Thoughts & random bits of info gladly accepted :-)
Back40
Old Dec 24, 2006 | 08:12 AM
Tanto's Avatar
Try and get it fixed before you go back. Sounds like you have an electrical gremlin from the sporadic nature of the CEL. Hopefully that and nothing more
Old Dec 24, 2006 | 08:29 AM
Electrical Gremlin... could a new battery help? I think it is original. I put a load tester on & it is just passable.
Old Dec 24, 2006 | 08:32 AM
Tanto's Avatar
Maybe. If it's just barely passable you need a new one anyways.
Old Dec 24, 2006 | 08:35 AM
My814x4's Avatar
There is a reason #2 and #5 cylinders are misfiring even if so slight you cannot feel it, possible water in the gas . The light flashs when the cat is overheated and is in extreme danger of a meltdown. When you have a misfire those cylinders are running rich and rich mixtures overheats the cat. Probably ought to have it looked at and diag.
Old Dec 24, 2006 | 11:17 AM
Darn... Thanks for the info. I'll have to figure out what to do now.
Old Dec 27, 2006 | 10:35 AM
Took it to a local shop, they called the dealer for parts..
This is scary... Dealer didn't know why I had platinum plugs.
Yikes!
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
