PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221
  1. problem when replacing CV shaft
  2. 98 4runner Newbe Question...
  3. Nominal upgrade to 02 LTD 4WD 4runner
  4. Should I pull the trigger???
  5. White smoke on startup?
  6. 3.4L 99 tacoma swap no spark or fuel! HELP!!!
  7. dilemma, Ideas?
  8. Bilstein Hd
  9. Savannah co op shakedown
  10. TRD Questions please..
  11. warm day no start problem
  12. do you have a 2000 4runner SR5 auto with rr diff lock?
  13. Having a little electrical problem..
  14. ob2 code
  15. Replace Lug Stud
  16. Upper Ball Joint Thread Damage
  17. Rear diff removal help
  18. Pics of my runner! 3" SS lift, 2" 4Crawler BL, Procomp Wheels, 33x11.50 Dick Cepek MT
  19. leveling heavy loads
  20. 200K mile 4runner
  21. Experience with Unichip for 3.4l 4Runner?
  22. VSV Location? Any pics?
  23. '97 4Runner oil recom., I live in Costa Rica
  24. cb antenna grommet
  25. 95 engine in a 88 truck
  26. changing cabs?
  27. OEM Shock/Spring life
  28. dealer support
  29. 2000 4Runner Suspension Question
  30. Cold weather vs Warm MPG
  31. Anyone not using a key fob for an 02 4runner?
  32. TRD Hawaiian Edition Sticker
  33. Help! Stripped Torx screw (steering wheel removal '98)
  34. Does your antenna go up in non radio mode?
  35. Making my truck louder with a turndown?
  36. Any writeups on changing TPS?
  37. exhaust systems
  38. Add A Leaf, Before And After..
  39. my lifted 4runner
  40. New Guy Kinda
  41. Newbie here in Cincinnati
  42. Drove my 4runner 4000 miles without an air filter.
  43. cricket lick chirping noise
  44. Destination MT in snow
  45. Belt slipping?
  46. Audio question.. Deep Cycle Battery vs. Capcitor
  47. cheap power for a 2.7
  48. Starting the plans for summer modding
  49. Ways to eliminate bouncy ride? 1999 4Runner
  50. 1999 4Runner Guage Cluster/AC/Gear Shift bulb sizes?
  51. new clutch installed.. fluid leak
  52. Cigarette lighter glow ring burned out....
  53. Hard start long crank time after not driving for a while
  54. 1800 mile tow
  55. How can i make my exhaust louder w/o $ anything?
  56. Building the best all around 4Runner. input appreciated!!
  57. 3500 RPM Idle...
  58. 4runner stall issue.
  59. loud click-click drains battery
  60. Paint job on bumper for 2000 4runner
  61. Spark Plug and Air Intake Question
  62. Noisy fuel pump
  63. 99 four runner $450.00
  64. Cyl. #2 Misfire major headache
  65. Can I get a ballpark price on a few replacement parts? (need it quick)
  66. Wheel fitment
  67. Help me out, by telling me what kind of wheels and tires these are.!!!
  68. 3.4L Headgasket issues
  69. 98 SR5 4x4 lift options
  70. Wanting some more power out of my 4runner
  71. Trans cooler question
  72. Too much fluid??
  73. Lift question I can't find the answer too..
  74. frame punch out
  75. Nylon rope trick for crankbolt
  76. Whats the best LED bulb to put behind my gauges?
  77. Pioneer AVIC-F90BT Double-DIN Nav installed
  78. tacoma rear end swap!
  79. 2WD shifter on 4WD 4Runner
  80. 98 4Runner Limited Fog Lights
  81. Right shocks for my lift?
  82. 4.0 1GR-FE V6 Swap...possile or not
  83. stiff ride
  84. trade power for mileage
  85. HELP! 3rd gen w/travel trailer
  86. Freshened up a bit
  87. Taco leaf springs
  88. AC Problem 3rd gen
  89. Blowing White Smoke Need Help
  90. exhaust bung question
  91. heater hose routing 3.4L 4Runner w/rear heater ASAP please !!!
  92. 01 sr5 overdrive slams into gear! Please help
  93. VSC & TRAC lights on (not CEL)
  94. throttle bodies???????????
  95. Can I make my door locks automatically lock when I start driving?
  96. Ever heard of a gun safe built into glove box?
  97. Land Crusier lift on a runner
  98. Taco squeals ! annoying! need help!!
  99. 01 4Runner Alarm/Keyless Entry Confusion
  100. 2 Problems with my 95.5 tacoma
  101. Need help with R150 R/R
  102. high altitude cold start problem
  103. Need opinions on a truck
  104. Drop in gas mileage?
  105. Clicking noise when trying to start, alternator?
  106. Do i need to change my diff oil?
  107. why is it so hard to find a bumper?
  108. New Runner
  109. New 35's on 17X9's...
  110. San Diego Test Fit: Pro-Comp 17x8" Series 97 or 99
  111. Does a '98 3.4L have an ign module?
  112. 99 4Runner - Interior LEDs, complete list
  113. Another...What the heck is this thing thread...
  114. Multiple coil failure?
  115. Idle, Gearing, and Speed. Thoughts?
  116. Where'd my horsepower go?!?!
  117. anyone in KC area? I need a local recommendation for tranny flush
  118. Toyota confirms diesel Taco for 2012
  119. swapping throttle body
  120. TRD Exhaust has arrived
  121. help me please!!!! idle at 2000 rpms
  122. wet oil filter any good?
  123. failed dc inspection (brakes) need advice
  124. 4Runner Exhaust Diameter
  125. What the heck is this?
  126. check engine light
  127. high idle all of a sudden help please!!!
  128. corner light amber reflector removal??
  129. Can I swap Taco 5 lug axles into a elocker rear?
  130. Limiting straps
  131. motor swap on my DD 84 pickup
  132. '05+ TRD Tacoma shocks and springs on '99 4runner?
  133. Which bucket seats and center console for me?
  134. 2004 Tacoma Front Air Dam?
  135. Fixing brakes- Doing the upgrade
  136. 4x4 or PreRunner?
  137. 4Runner v. Tacoma
  138. Temperature Control LED Conversion Write-up
  139. Illuminated door handle write up..pic heavy..
  140. My 2003 4-door taco 4x4
  141. Toolbox inside camper shell??
  142. Wrong torque setting
  143. Where Did You Install The Front Speaker Cross-Over???
  144. P0125 code HELP!!!
  145. Stuck in the middle of body lift, a little help please :)
  146. LED dash light color opinion (post pix if u have them)
  147. anybody know this truck in san diego? 2002 TRD taco 5spd with supercharger
  148. Installing OME 881/906s '974Runner
  149. Trail Gear Rock Sliders...ON
  150. Desert Dune touch up paint...
  151. 2000 4Runner 4wd SQUEAKS LOUD!
  152. Cannot get crank bolt off
  153. How to install LED tail lights
  154. Trying to get FOG lamps to turn on *independently*, still....
  155. key not removing from ignition cylinder...fix
  156. Intermittent oil pressure problem
  157. Is my bent axle causing my wobble at speed?
  158. Steering Rack: Toyota Reman vs. Others
  159. Multiple Cylinder Misfires!!! Common 96 4Runner Problem???
  160. 1" 4crawler Body Lift Install
  161. LED Guage Light Install How-To
  162. 1997 Limited Catalytic Converter
  163. Service Suggestions?
  164. Kenwood DNX5120 Nav System Installed in my 02 Runnner <pics>
  165. 96 4runner 02 Wiring ??
  166. Power Antenna doesnt want to work
  167. help! clutch falls to the floor
  168. No Heat?
  169. how many miles do you have on your automatic trans?
  170. arc,spark, now no pass side lights!
  171. Double Cardan U-joint Teardown '02 Tacoma
  172. 3rd gen Runners,let's see your rear bumper dent
  173. Won't Shift into gear
  174. Transmission Shift Celenoid "B" Code
  175. 1998 4-Runner IAC Question
  176. spark plug replacement...
  177. want so badly to get my lift on!
  178. 98 taco speed governor
  179. Toytec top plate spacer. Do I need extended studs?
  180. Question for those who run Borla exhausts
  181. 3rd gen 4Runner rear bumper
  182. Tacoma Lag
  183. California Dismantler
  184. "a/t p" mess. on dash, no go !!
  185. CEL after pusing RR DIFF LOCK
  186. is removing the swaybar from the front okay
  187. new lift installed
  188. installed a light in the center console compartment today, take a look at the pics
  189. 2000 ish 4Runner cluster help please .
  190. True Front Door Speaker Size?? (2002)
  191. Advice on buying 02' 4Runner SR5
  192. Put my lift on and got some new shoes! w/ pics
  193. Transmission Filter change gone... not quite sure
  194. is my clutch going?
  195. new to me 1999 4x2 truck
  196. IPF/ARB Rocker Switch Cover
  197. Seatbelt tip
  198. Bilstein 5100 vs HD On a 4 4unner
  199. Blackstone Laboratories & my new 97 T4R
  200. Name This Part (Photo)
  201. wire harness wont fit
  202. my sunroof is stuck
  203. What Backspacing on '99 4runner Wheels?
  204. electrical problem (gauges stopped working)
  205. Runner stalls when wet
  206. Old Man Emu or Sonoran Steel?
  207. Code 420 Help!
  208. Lifted the 4runner yesterday, pics
  209. 2" leveling kits for tacoma
  210. transmission help, searched all day
  211. 98 4runner check engine lightand running rough after cleaning engine bay with water
  212. keyless entry
  213. Harmonic Balancer/ Belt Issues
  214. More Bumper rot
  215. New to Yota's
  216. Beef'd links, Beef'd gas tank..... and 1st gen roll bar installed.
  217. Thumping tranny!
  218. 2002 Tacoma jerking/shuttering problem
  219. Transfercase counterbalance
  220. where to get Cornfed spacers?
  221. help with keyless entry programing
  222. 4runner Won't Start When Warm - leaking (leaky) fuel injectors
  223. Anyone running LC shocks in the rear with LC coils?
  224. check out the deal i got, i think.
  225. Crashed 99 TRD X-cab ReBuild
  226. 17" Tacoma rims on 3rd gen 4runner?
  227. What is normal oil pressure?
  228. Lifted Runner 4 sale Q's
  229. Ever wonder why the 5VZFE has different spark plugs for each bank?
  230. Any difference in TRD and "regular" coilover springs??
  231. 2002 Toyota 4 Runner Ride Quality
  232. Wanna swap your painted grill/bumpers for chrome?
  233. Automatic transmission questions.
  234. Fog light mod revisited on 2000 4runner
  235. Right way to install new bushings??
  236. 2004 SR5 PreRunner Towing Question
  237. Alternator Whine?
  238. 89-96 Inclinometer Altimeter on Ebay
  239. DVD Multi-Media Install-another Gen3 Mod
  240. 4runner taco whip antenna mod?
  241. OIL LIGHT CAME ON? need advice
  242. SHHH noise from engine with quick accel.?
  243. HELP?? Keyless driving??
  244. need to hear your take on this....
  245. SRS Replacement Questions
  246. Painting faded black pieces
  247. problems you have with big tires/lifts?
  248. 3rd Gen VS. FJ
  249. supercharger belt setup
  250. 4Runner rear end feels off balance? :(
