3 Inch Suspension Lift
Old Apr 15, 2009 | 07:37 PM
sctaco01's Avatar
I am looking for a 3 inch suspension lift for my 2001 Tacoma 2.4 2wd. I have looked into the Fabtech 3 inch and wanted to see if anyone had any experience? The big question is if the fact that my rear axle sits on top of the leaf springs would do anything.
Old Apr 15, 2009 | 07:57 PM
sctaco01's Avatar
It said that it was a add-a-leaf.
Old Apr 15, 2009 | 08:02 PM
SpecialScottie's Avatar
So your truck is spring under?
Then an add a leaf wouldnt lift it too much
Old Apr 16, 2009 | 07:10 AM
eddieleephd's Avatar
have you thought of putting the axle below the leafs?
this should give you about 3"s lift!
Old Apr 16, 2009 | 09:12 AM
Gerdo's Avatar
Doing a spring over conversion would be a good way to gain lift if done right. If you or someone you know is capable of doing the work it would be fairly inexpensive. I'm guessing that it is a 5 lug wheeled Tacoma. ToyTec (Click Here) has lifts for your year but not for 5 lug. Call Doug at ToyTec. He should be able to help you. He may have a lift that is not listed that will work.
I'm not sure what the difference the amount of lugs has to do with the suspension.
Old Apr 17, 2009 | 10:23 AM
sctaco01's Avatar
I emailed toytech and they dont carry anything for the 2wd 5 lug.
Old Apr 18, 2009 | 03:36 AM
Lightbulb
Call Alcan they will make you leafs for what ever lift you want!!!
not sure about the front! I run OME!
I really do like my set up!
The only time I do not like the ride is when wheeling too hard, damn sway bars!!!
I will take them off some day!
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
94ofCanada
Aug 14, 2015 06:37 AM
bobpat
Aug 1, 2015 09:25 PM
Vargntucson
Jul 4, 2015 12:15 PM
