rear, drum brakes hardly work???
Probably just need to be adjusted. When you pull the wheel before you pull the drum, spin them and see if there is a little resistance. If there is then there adjusted fine. They should just barely rub the drum when there adjusted right. How do you now there not working properly? Is it just the way it feels? I noticed these trucks tend to dive a little when you brake hard on them. Most of the braking if from the front. You can manually adjust the drum at the back of the drum or if you drive in reverse slowly and pull and release the hand brake it'll adjust them aswell.
rear brakes
OK, I notice the lack of rear brakes with going down a steep driveway or when backing my boat down the ramp. My front tires slide and the rears do nothing as far as I can tell. I've had this problem for a long time and the last time I changed my front pads I adjusted the rears but it didn't help. OH, no problem with rear seals.....yet!
cchinny
06-25-2015 08:11 PM
Mr.Black
06-21-2015 10:17 AM
