Liquids leaking
Old Apr 14, 2009 | 10:10 AM
Loucifer's Avatar
Liquids leaking
I found a leak under my rig today. It is from a tube next to catalytic converter, appears to be coolant. Also, the coolant levels are wicked low. How much would a line replacement cost?
Old Apr 14, 2009 | 10:38 AM
gpcollen1's Avatar
If it is the metal lines running to you rear heat, remove the metal lines and/or just replace them with rubber. For a temporary fix, if you do not currently need rear heat - get under your hood and just bypass the rear heat. This should be apparent once you look at it but you are just rerouting the rubber hose connections so nothing goes to the lines running to the rear heat...
Old Apr 14, 2009 | 10:48 AM
BigBallsMcFalls's Avatar
rear heater. those tubes do corrode. it happens.
bypass them or dealer fix 250 bux
Old Apr 14, 2009 | 11:28 AM
3w41d's Avatar
or buy some brake lines and bend them yourself
worked for me
Old Apr 15, 2009 | 09:02 AM
Loucifer's Avatar
Oh hell, that isn't bad at all then! Considering that the snow is finally melted up here, I would consider making that a project for the weekend. Much better that spending 250 bucks!
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
