Trans cooler question
Old Apr 6, 2009 | 08:22 PM
BMWToyotaMan's Avatar
Does the Radiator have a dual core coolant/trans? I looked under the runner and saw the fluid lines running to the bottom of it.
Is this good enough for towing or is another cooler recommended? I will be towing a uhaul 6x12 trailer later this month and want to make sure its ready to roll.
Thanks,
Jeff
Old Apr 7, 2009 | 02:57 AM
KZN185W's Avatar
With Toyota's Towing Package for the 3rd gen 4Runner, they included the TRD ATF aux cooler. I would recommend that you get that or another one with the same design or better
Old Apr 7, 2009 | 09:19 AM
gpcollen1's Avatar
Tranny cooler is a must unless that trailer won't be loaded with anything and you are just driving around the corner. You can just grab one at Napa or somewhere and have it on in under an hour.
Old Apr 7, 2009 | 09:31 AM
I will be going through the mountains of West VA so it sounds like it will definitely be needed.
Thanks for the help
Jeff
Old Apr 7, 2009 | 09:34 AM
I am going to order the trailer lights kit from Etrailer, anyone know which transmission cooler I should get from there? What size fits the best?
Thanks,
Jeff
Old Apr 7, 2009 | 09:38 AM
Godzilla's Avatar
An extra in-line tranny cooler or even a bypass cooler is ideal for towing and or regular driving.
There are extensive threads on here regarding transmission coolers and the types recommended. Please search this.
Old Apr 24, 2009 | 07:25 PM
DIHOWARD's Avatar
I got mine from Derale. It's run in series with the radiator cooler and a remote filter with an oversized K&N filter. adds another quart of tranny fluid to the whole system. I run around 180 degrees pulling a 2000 pound boat.
Old Apr 25, 2009 | 08:42 AM
I ordered a Hayden from Macko and installed it last week. Ready to tow!
Old Apr 25, 2009 | 12:31 PM
tom_mag's Avatar
To reduce heat when towing don't use overdrive. If it is a one time thing I would consider just changing the fluid after you are done towing.
Old Apr 25, 2009 | 03:37 PM
KZN185W's Avatar
good buys would be any of the following:
TRD ATF cooler - Toyota dealer
B&M TransCooler - Summit Racing
Hayden Cooler - Summit Racing
Tru-Cool LPD Cooler - IPT
get a cooler rated for at least 20,000 GVW
this_guy
Aug 10, 2015 10:44 AM
this_guy
Jul 31, 2015 01:27 PM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
