4runner Best rear coils to use w/ moto carrier
Old 04-27-2009, 09:49 PM
Tom2000t4r's Avatar
Exclamation 4runner Best rear coils to use w/ moto carrier
Need help w/ coils.
--I suppose my stock 2000 springs are shot if i can bottem them by just pushing on the bumper???
---Is is possible to maintain decent ride and be able to load 260+ pounds of extended tounge weight???
--Is OME the only brand out there???
--and is the lowest price for them about 160??
--How about adding air shocks???
--Which ome springs are heavy duty yet still ride nice?? i see a 906, 890,891,892
Old 04-27-2009, 10:02 PM
xjdubber's Avatar
id look into getting some new springs and air bags, they would work really well for you.
Old 04-28-2009, 02:22 AM
jimig's Avatar
Originally Posted by Tom2000t4r
Need help w/ coils.
Yes
No
No https://www.yotatech.com/forums/f37/...g-sale-179545/
no
891
Plenty of options out there.
Old 04-28-2009, 04:07 AM
crolison's Avatar
ome 891's
Old 04-28-2009, 06:12 AM
okie81's Avatar
When i hookup my moto carrier, I don't notice any difference in the ride
Old 04-28-2009, 08:28 AM
quattro's Avatar
Previously I ran the Gabriel AirRide shocks from Napa on the back and regularly used a MotoJackRack with a KLX650R (call it 400+ lbs all in). With 100psi in the damper-bags the truck rode quite well.
The absolute capacity of the AirRide shocks are 250psi, which I used when I carried an onboard compressor capable of it. Came in very handy when towing heavy loads like a rally-car and gear.
I've now got the stock springs, AirLift 1000 Airbags in those springs, and Bilstein HD's. I haven't hooked up the Moto carrier yet to see if it works as well.
Old 04-28-2009, 08:37 AM
gpcollen1's Avatar
http://www.wheelersoffroad.com/ome4runner.htm
Old 04-28-2009, 10:54 AM
SoCalPaul's Avatar
Get new springs. Nothing wrong with OME.
Old 04-29-2009, 10:52 PM
Tom2000t4r's Avatar
thank you for the replies. I guess i'll try the 891s
I suppose 892s would be overkill?
Old 04-29-2009, 11:48 PM
scuba's Avatar
I dont think they would be overkill, But they are probably going to ride realllllly stiff unless you have some weight back there..
They do say they give the same lift as the 891's..
I know someone else will chime in..
Old 04-30-2009, 06:47 AM
frodin1's Avatar
I'm currently running 890's however, I did try the LC coils. I didn't like the raked look when unloaded. But with a certain amount of weight they would be nice. I liked the ride of them and they towed awesome. If I was going for an exterior tire carrier and bigger rear bumper that would be my choice. The 890's are good as well, but I'm not carrying anything. I get a little drop in back when the boat is hooked up.
Old 04-30-2009, 02:57 PM
Tom2000t4r's Avatar
so my question now
which springs are better for a moto carrier 890 or 891?
Old 04-30-2009, 03:54 PM
j-man's Avatar
891's...go for em.
Old 06-21-2009, 03:58 PM
Parker Runner's Avatar
I have the medium duty rear coils. They work fine but do ride a bit rough. Keep in mind, the 4runner is a truck (body on frame). I also have the airbags from firestone which work ok.
If you want a softer ride, lower your tire pressure in the rear (at your own risk). I run about 26 PSI in the rear which works ok.
I towed a 2600lb trailer off the back of my Versahaul bike hauler. With the bags it works fine. However, if you slam on the brakes (and the trailer has none) you will push the front wheel off the ground. Pretty exciting.
Old 06-21-2009, 06:42 PM
xjdubber's Avatar
if your front wheels come of the ground under hard braking you either have your trailer loaded wrong, or as in your case a wrong hitch setup towing a trailer of a bike carrier puts immense amounts of extra tong weight on your hitch, you can end up doing a lot of damage that way. both situations come down to having to much tongue weight.
Old 06-21-2009, 06:46 PM
Front wheel-singular. And yes, you are correct. I had a 2600 lb trailer sitting about 4 feet off the rear end with a TTR250 sitting on the extender. It was a lot of fun-quite the adventure.
Not sure about the damage part, it wasn't like I was hopping the front end ghetto style. Just enough for the ABS to kick in. The 4runner is pretty tough.
Old 06-21-2009, 07:03 PM
xjdubber's Avatar
i would'nt be worried about the front end more the rear frame.....
also with how you describe that what do you think would happen if you were coming around a sharp corner and braked hard?
Old 06-22-2009, 11:32 AM
It's all about preparation my dear friend. All about preparation.
Old 06-22-2009, 05:43 PM
xjdubber's Avatar
I've seen what trailers can do to frames and even ball mounts, ever seen a 2" solid ball mount twisted like a pretzel? I have...... I like to be prepared before i leave my driveway. A proper trailer setup can save lives.
Old 06-22-2009, 05:49 PM
It was far from proper. But still fun.
Quick Reply: 4runner Best rear coils to use w/ moto carrier
